05-11-2004, 11:28 PM | #1 |
Confirmed Truckaholic
?? about brackets for the truck buckets
I picked up a set of brackets that go on the pass. side bucket seat. The holes don't match the holes in the cab, do the brackets sit flat on the floor??? That's what it looks like to me, I've never really seen origanal truck buckets.thanks
05-12-2004, 10:04 AM | #2 |
Resident Curmudgeon
If you are replacing a bench, then you need to drill new holes. I used the existing front outside hole for the bench mounting and drilled 3 others. Someone said this was not 100% correct but my seats place the pass and driver in correct positions so if it's not 100% correct it's darn close. No, the bracket does not sit flush on the floor either. Assume you have the truck style fixed passenger brackets
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
