Old 05-12-2004, 05:25 AM   #1
craigg1
Spray in bed-liner
My truck bed has a lot of deep surface rust (but no rust through areas) so im thinking about going with a spray-in bedliner. What is the best way to remove the deep surface rust or will the spray-in liner (line-x) keep the current rust from spreading? I have also been reading about rust converters, but dont know if thats the best way to get rid of the rust before adding the spray on liner.
craigg1 is offline   Reply With Quote
Old 05-12-2004, 07:48 AM   #2
JimKshortstep4x4
I would blast it to remove the rust.
Jim
Old 05-12-2004, 09:09 AM   #3
dubie
dubie's Avatar
I agree. Have it sandblasted then have it treated with POR 15 or another rust preventer, then have the spray in bed liner installed. You will never have another problem with rust
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 05-12-2004, 11:22 AM   #4
greasemonkey
greasemonkey's Avatar
When I got my Speedliner, they actually sanded the bed to bare metal by hand, primered it, then sprayed in the bedliner. My rust wasn't quite as bad as yours though.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 05-12-2004, 11:27 AM   #5
craigg1
Yea, I called the local Line-x dealer and he said they did prep/sand the area first, I just didn't know if they would do a good complete sanding job on the bed of my truck. Guess I just need to take it down to the Line-x guys and see what they will do.
Old 05-12-2004, 01:14 PM   #6
724x4a/cchevy
Self-proclaimed LED man
724x4a/cchevy's Avatar
I have speedliner. On my truck, they sanded the bed down, sprayed an adhesive promoting primer, then applied the color matched speedliner. If i were you, i would put some caulk or something in the cracks where the wheel tub meets the fender and where it meets the floor. My tubs are trying to rust because the bedliner cant get between the two layers of metal.
724x4a/cchevy is offline   Reply With Quote
