Old 05-12-2004, 08:15 AM   #1
veltex
veltex's Avatar
small carb on big motor
anyone running a 650 performer on a 454? Is it enough gas? I am changing out my 396 for a 454, 40 over, roller everything, 8.8 to 1, 049s, quite a bit of lift, low end power, all in by 5000rpm, should be a great truck motor just hoping I had enough carb, its new so I want to use it if I can. Any info helpful, thanks
beater 65 gmc at the moment
veltex is offline   Reply With Quote
Old 05-12-2004, 08:28 AM   #2
stepside454
stepside454's Avatar
Id say you need about 680 CFM for a 454 that goes to 5000 RPMs. Id use either a 670 Holley with a 1 inch open spacer or a demon 725CFM. John
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 05-12-2004, 12:01 PM   #3
junkyardjohn
junkyardjohn's Avatar
650 CFM HAS PROVEN TO BE A LITTLE TOO SMALL FOR BIG BLOCKS IMO. EVEN STOCK 396s SEEM TO REQUIRE MORE FUEL THAN THAT. I LIKE TO USE EITHER THE 750 OR 800 CFM EDELBROCKS. JOHN
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 05-12-2004, 02:31 PM   #4
shortymac83
hmm...
shortymac83's Avatar
I've calculated that a stock olds 455 that goes to 5500 RPM's technically should only require 630 cfm, however practical experience will lead me to think that a motor that big really needs at least a 750 carb. I'd go with a quadrajet.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 05-12-2004, 06:15 PM   #5
stepside454
shorty, I calculate a 5500 RPM 455 needs 742 cfm, so a 750 would be a about perfect. But I do agree with the Qjet, hard to go wrong on a properly tuned Qjet.
Old 05-12-2004, 10:44 PM   #6
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The stock Q jet is either 750 or 800 cfm depending on the engine, so a 750 cfm Holley or Edelbrock will be fine.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 05-12-2004, 11:07 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Even though they are right that the engine could use more, and at 5000 RPM would need more...in all reality, the engine will run fine and rev to redline with no problems. This carb could even boost low end torque by keeping the intake charge velosity up.
Old 05-14-2004, 12:53 AM   #8
veltex
veltex's Avatar
thanks all, I will know soon enough, might have new motor on the road Sunday.
