04-03-2002, 09:19 PM | #1 |
Old member
? about adding a extra fuse block.
Boy what a day here in SC. Close to 70 degrees. Ok for the ? I got a complete fuse box out of another truck, and was thinking about adding it to mine for all of the extra's I've added over the last 16 yrs. I left about 10" of wire off the back so I could tie into it, then run all the extra's off of it and try and clean up under the dash. What do you think?
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 http://geocities.com/chevy71tpi/main.html
