Spacer or sleeve for motor mounts?
I have a 68 gmc that I will be installing a 350/350 setup in the next few days. I have the engine motor mounts and the frame mounts. Is there a spacer or sleeve for the bolt required? If so does anyone a p/n for gm or napa? Otherwise I guess I'll just use a 3/8x16x2" grade 8 bolt with a large flat and lock washers...
Thanks! ![]() |
