Old 05-12-2004, 11:49 AM   #1
Austin318
Austin318's Avatar
Grill off 72 fit on 70 ?
Now I'm looking at a 1970 LWB. I prefer the 71-72 front end so whats required to get a 72 front grill on a 70 LWB truck ??
Any major difference's other than grill and drum brakes ?
Austin318 is offline   Reply With Quote
Old 05-12-2004, 12:32 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
It will swap right in.
You do however need to change the hood latch and center grille support.69-70 share the same design,71-72 share a different design.
Of course the turn signals in the 71-72 are in the front bumper so you'd have to swap that in as well.
It all just bolts in once you have the right year parts.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 05-12-2004, 01:35 PM   #3
Austin318
Austin318's Avatar
Ok thanks now I'm not so worried about looking at pre-71.
Old 05-13-2004, 03:40 PM   #4
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
You do not need to swap the hood latches... I did the same swap on my '70. I torched the center grill support and grinded it smooth. The swap was super simple. I put the signal lights in the 'original' postion, but mounted them to the radiator support, so there were behind the inner grill.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 05-13-2004, 09:40 PM   #5
Austin318
Austin318's Avatar
Good I idea I had'nt thought about mounting the lights behind the grill but I still dont own one yet so I dunno what year I''ll end up with. Hav'nt had much luck on looking with the weather.
