what spring loaded poppers do you use. I'm getting a pair of new ones because the one that came with the kit are garbage and don't open the door enough to fully unlatch it.
Dennis |
It followed me home?
I use a brake spring. Are you sure the latch or door is opening correctly? I went a few months without a spring and had no problem at all
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
The latch and everything seems to be good. My prob is that when the door unlatches it catches the safety catch and I have to pop the door for a second time while pulling on the door..... it just doesn't look like the popper has a long enough stroke to fully push the door open. So I figer I just need a better quality popper.
Also.... where is the popper mounted..... mine is at the bottom corner where the rubber door stop used to be.( Just a dumb question)
Dennis |
its just $$$$$
I never used a popper on my blazer. It always popped open with no problem, well except the one time the battery went dead.
