05-12-2004, 11:06 PM | #1 |
Garage Queen Material
ideaR???
has anyone heard of or seen someone in a truck, any truck, connect there cab and bed together(not like a blazer) but through bolts to help with the frame flexxing under heavy turns?
i know a 2wd blazer will handle a lot better than a pickup, since the bed is connected. |
05-12-2004, 11:21 PM | #2 |
Happy to be here
The only way I have seen it done with success is with down tubes on a roll cage. I can't imagine you getting enough strength to control body twist by bolting them together...
05-12-2004, 11:34 PM | #3 | |
Ken Morgan For fun: 1964 Volvo 122 For slow: 1984 Chevrolet C-10 For everything else: 1997 BMW M3 |
05-12-2004, 11:37 PM | #4 |
what got me thinking was our state is starting a new advertising thing "buckle up in your pickup"
saying how much easier they are to roll over compared to a car. if i had time to box in the frame, i would have time to do a full off-the frame restoration which i would really love to do |
05-12-2004, 11:41 PM | #5 | |
05-13-2004, 09:01 AM | #6 |
BeWarE tHe eViL CrAnkTOe!
yes but look at the truck they are showing you lol.. a wheel gap havin 75 series tire usin Ford. lol of course it will roll easy. A lOwered truck is much harder to roll unless your being really crazy.
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
05-13-2004, 09:08 AM | #7 |
Happy to be here
Yeah, Dave is right. If that's all you are worried about, just lower it some more...
05-13-2004, 09:48 AM | #8 | |
SO MISGUIDED! I hate that not safe junk and roll over junk. You adjust your driving to what you drive. An example I once read was they compaired a Vett to some SUV or Mini van. They took the number built and then how many rolled. They got a percentage of roll over accidents. Guess what. More vett end up on their lid then the other high CG vehicle when you look at it Builtvs rolled. If this BS is alowed to continue we will have to wait to be insppected befor leaving for work everyt morning. This is how junk like Airbag and anti loc are not forced on you. I want neither so I no longer drive cars newer then 90. end rant. As for joining the body to bed. K5's tear the body up off road from flexing and they have a much shorter wheel base. If your wanting to make it more ridged then I would go a full roll cage tied to the frame. That would do the most to improve safety and rigidity and handling verses money spent then anything else you could possibly do. Add rear sway and 1 ton front sway all poly bushings in front end, Track bar on the rear and you can make it handle. Ride will suffer but it will handle.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
05-13-2004, 09:50 AM | #9 | |
05-13-2004, 12:39 PM | #10 |
No, it was an El Camino
05-13-2004, 02:37 PM | #11 |
ocbaud,
don't listen to the government! people roll SUV's and trucks more because they cannot drive correctly and refuse to believe that they are not driving a porsche. there are literally thousands of 73-87 trucks out there at stock suspension height, and how many have you heard of that had severe problems (well, aside from the saddle tanks...)? Also, you never have to modify a vehicle from stock setup to meet certain laws. Especially something like boxing in the frame. This applies to other things as well, such as shoulder belts (or hell, seatbelts) and airbags. I don't see too mamny people swapping airbags into their trucks just because the government leads you to believe that trucks are unsafe.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 05-13-2004 at 02:38 PM. Reason: dumbazz cnat spel |
05-13-2004, 04:07 PM | #12 |
trust me guys, i'm not worried 1 bit about rolling my truck. i drive more carefull than that
i was just wondering if by connecting the cab and bed, it would improve handling. i really want the truck to handle as well as possible(with the current susp. setup) |
05-13-2004, 05:16 PM | #13 |
LED King
Moonlight - is it the cabro or challet thing? Am I close? The big thing with a camper.
Tyler 1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles 2006 Ford Focus ZX3 5-speed Stick 2016 Chevy Spark EV Gone: 2002.5 VW GTI 24v VR6 Gone: 2008 VW R32 |
05-13-2004, 05:32 PM | #14 |
the Chalet was based on a Blazer...I'd guess its a motorhome, since its based on a C30 chassis :p
EDIT: I would like to see pics of your truck, please email to athorich "at" kent.edu ...thanks
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
05-13-2004, 05:44 PM | #15 |
LED King
Pics of my truck? Who are you talking to?
05-13-2004, 06:24 PM | #16 |
sorry, I meant moonlight...I want to see this "thing" he's got...
05-14-2004, 03:04 AM | #17 |
ROCKET POWER!
There are a few important things that need to be given thought above others. First off, the frame is made out of mild steel C-profile bent into shape. Second, the crossmembers are made out of sheet metal cut and bent into the right size, and then riveted to the C-profile. The suspension relies on the same principle, hydraulic pressed mild steel sheet A-arms, brackets, spring hangers and so on. GM did it to keep cost down, but more importantly they wanted the frame to flex under load because it's more durable that way. The same applies to your cab&bed, it needs to be isolated from the frame with rubber bushings so the frame can flex, and the cab&bed can flex on their own. You can not make the frame too stiff, or it will break where the yield point of the material is exceeded. That doesn't mean you can't improve the design, but there must be some flex in the frame.
What did i do last nite? I had a wonderful time, That's what they tell me What did i do last nite? 1979 C-10 shortfleet: Olds 350, Th400, 12 bolt Current project: 1969 Olds 455 W-30, needing a rebuild |
