Old 05-13-2004, 03:32 AM   #1
2birds40
motor mounts
i am going to swap in a v8 in place of the inline 6 the motor is coming out of a 86 gmc pickup i have the whole truck can i use the mounts from it or will they not work by the way it is a 2 wheel drive and it is going in to my 67 4wd thanks for all your help you guys are great
2birds40 is offline   Reply With Quote
Old 05-13-2004, 06:10 AM   #2
dmurphy68
you can drop the whole k member and make it disk breaks up front. i was told it is a direct bolt in. you can use 73-88 to do this.
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 05-13-2004, 08:28 AM   #3
2birds40
the truck the v8 is coming out of is a 2wd. the truck the motor is going into is 4wd. so i don't understand what you are saying about getting disks thanks for the reply
Old 05-13-2004, 10:24 AM   #4
Burnsman
Chevy Freak
Burnsman's Avatar
motor mounts
If I remember correctly, it should be a bolt in. I think the crossmember is the same. I'm fairly certain, but maybe others can jump in. You'll need to get the older style motor mounts instead of the 86 style to bolt to the crossmember though. The 6 cylinder ones are different. I may even have some. You can have them for free when you come down and get your other stuff (if I can find them). Brian
69 GMC SWB, 350
70 Chevy LWB, 350
55 chevy gasser, 461
73 Camaro, 496
67 RS Camaro, 406
64 Chevelle, 588
71 Nova, 565
67 Camaro, 461
Burnsman is offline   Reply With Quote
