Old 05-13-2004, 03:21 PM   #1
teeitup
Just like to part out trucks!!
teeitup's Avatar
Dana 44 front end ????
I got about 10-15 dana 44 frontends, some were out of 71-72 and some 73-80, anyway how do I tell the difference between them? Thanks for the help, Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 05-13-2004, 05:34 PM   #2
drink2mny
drink2mny's Avatar
Well I'll help ya out Randy but your going to have to bring them all over to me so I can very what they are.. I PROMISE to send them back to unmolested Especially if they have the flat top knuckles on the passenger side..
anyway TTT
Support The Board
drink2mny is offline   Reply With Quote
Old 05-13-2004, 06:07 PM   #3
mkmiller1
mkmiller1's Avatar
Randy,
I believe the d44 from 71-77 have the "flat-top" knuckles(it is a flat part on top of where the tierod end attaches) and 78-^ don't have the flat top, it's more rounded on these models. I saw a set of flat-top knuckles on ebay the other day going for about $70 with 2 days to go. Someone please correct me if I'm wrong on the years.
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 05-13-2004, 06:26 PM   #4
1969 GMC
1969 GMC's Avatar
iirc, the 71-72 dana 44 is a bit smaller than the 73-up version. larger axletubes and ujoints, diff is the same.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-13-2004, 06:46 PM   #5
ryanroo
ryanroo's Avatar
Randy, im not sure about anything else but if i remeber i read somewhere that the 73 and older 44s use the smaller 230x(?) axle joints and the 74 and newer 44s use 297x u-joints in the axle. this may be incorrect though.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-13-2004, 08:50 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Ryan's close it's the 260x u-joint to the 297x in 73 and newer. Some 72s had the 297x also.
I thought the small axle tube versions appeared in the 70s on certain models while others of the same year got the larger tubes.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-13-2004, 08:57 PM   #7
jhow66
jhow66's Avatar
My son (orangeuavol) has a 72 Blazer that he just rebuilt the 44 on. It has the flat- top knuckles on both sides and small u-joints. By the way does anyone know where we can get one of the tapered sleaves that is used to bolt the steering arm on. (we lost one).
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 05-13-2004, 09:58 PM   #8
teeitup
teeitup's Avatar
Thanks guys for the help, I'll try to look at them tomorrow after work. Thanks Randy
1980 chevy swb 4x4
Old 05-13-2004, 10:51 PM   #9
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
How do you identify the differences between the 260x u-joint and the 297x u-joint?
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 05-14-2004, 12:19 AM   #10
ryanroo
ryanroo's Avatar
the 260 is smaller the same size as most dana 30s use, the 297 is bigger. visually without both side to side to compare you just kindof need to know about what each looks like, or measure them.
Ryan
72 K20 12v build
Old 05-14-2004, 03:31 AM   #11
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
http://www.falconsteering.com/ujxref.htm
Here's a cross reference for the different u-joint manufacturers. NAPA sell the precision.
The difference is about a 1/4" in width.
Both my 70 and 71 have flat top knuckles.
Old 05-14-2004, 06:43 AM   #12
Blazer1970
Blazer1970's Avatar
If you really want to know what the axles are, get the BOM numbers off the axle tube and run them here http://www.drivetrainsuperstores.com/. You can get the original year and application.
Blazer1970 is offline   Reply With Quote
