05-13-2004, 07:23 PM | #1 |
Truck addict
converting auto to manual
how hard is it to do this conversion? The truck I am looking at is a 350/350 auto, and I told myself my next truck would be a stick, it is not original so I am not worried about modifying it, just wondering how hard it would be.
1956 Chevy Napco 1972 Cheyenne Super 1970 K20 |
05-13-2004, 07:44 PM | #2 |
Well You Will Need A Floor Shift Colium....
Just Happen To Have A Red One.....65.00 Plus Shipping |
05-13-2004, 07:53 PM | #3 |
Almost done!
Iv'e got a 3 speed transmission out of a 1970 swb. Changed it to an auto. You will need a cross member, shift linkage, clutch rod and bracket, clutch pedal, bell housing, clutch and more. I just trashed most of what you would have needed. The only thing I kept was the trans and the aftermarket floor shifter. If you need them, let me know.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
05-13-2004, 08:10 PM | #4 |
Fabricate till you "puke"
i cant help with parts, but will say that the 3 spd sag trans will bolt down in the same spot that the 350T was bolted to(auto crossmember). You dont need to worry about the bell mount crossmember ,unless you are planning to run a 4 spd truck trans. As far as the conversion, its pretty straight foward......as long as you have all the pcs you need good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
05-14-2004, 12:03 AM | #5 |
i put an sm465 in my truck, you are going to need, trans, clutch linkage and pedal assembly, crossmember, driveshaft.
if you need i have the pedal assembly if you need it just let me know, i used the 3spd column that was in my truck just did not hook up anything on it.
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
05-14-2004, 03:12 AM | #6 |
Truck addict
thanks for the help guys, I might need some of those parts, but first I have to buy the truck
05-14-2004, 01:05 PM | #7 |
I did a 4 speed to 700R swap. The parts are here if you need them.
Bill - Tucson, AZ 47 Chevrolet 2 dr sedan 56 Chevrolet 210 2 dr sedan 66 Chevrolet Malibu 2 dr 4 speed 71 Chevrolet C30 Longhorn 86 Chevrolet Monte Carlo SS (Sold) 01 Chevrolet Tahoe IM - BUSTERWIVE@aol.com |
