SOON TO BE A STEP SIDE
Will 67 Fit On 76 Frame?
both trucks have I6
both trucks have 3 on tree 76 has power disc brakes and power steering both are long beds will 67 sheet metal go on 76 frame or should i rob goddies from 76 and put on 67 frame all opinions welcome 76 truck is $100 runs /shifts/moves
67 CHEVY LONGBED----- BEST 51 DOLLARS EVER SPENT ON EBAY! 4.3 LITER INJECTED MOTOR WITH 5 SPEED GOING IN SOON |
no, it won't fit exactly, the wheelbases differ 127 for the older and 131(?) for the newer frame assuming you are dealing with LWB the SWB are different to. there was one here in town someone did and there was a space between the cab and box, looked like sh*t and the body mounts have to be changed to fit, so just rob the goodies from the 76 in my opinion
Ryan |
Mudder67 has a 67 body on a 1976 frame. You might wanna contact him.
Southern but in Ohio!!!!
It can be done my 69 4x4 is on a 79 frame, the mounts are not the same, you can take some of the frame out for the right wheel base, or have a gap..... its not that hard to do if you have the tools to do the job & freinds that will help......
1969 C/10 3/4 ton 4x4 longbed custom, frame made from a 79 1972 custom-10 half/ton longbed 1980 1/2 ton 4x4 all original 350/350/205 with air Eaton,Oh rebelryder@hotmail.com |
#5 | |
Sound like it would work???????
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
thanks for the info
It can be done, I have 67 on 76, but we made a home made 3 inch body lift underneath it that lined up with the 67 body.
1967 Chevy on 1976 3/4 ton Frame with bored over 427. My white beauty. Last edited by jpeters79; 05-17-2004 at 02:09 PM. |
