Metal Fuel Line Setup Pics
I am finally getting around to removing the 8 inch run of rubber fuel hose and replacing it with metal line. I am going to go ahead and replace the entire line from the fuel pump to the fuel filter. Can someone post a pic of their setup so I can get an idea on how to run the line. Also what size fuel line will I need?
Thanks Much |
If it is a v8 I would use 3/8 line..
Forgot to add that. It is a 350.
I believe also they make those pre bent and ready to hook up, I would call an auto parts supplier and see, it sure would save you some time and frustration....
auto zone
try this braided fuel line from auto zone $19.99
Here's a pic of an NOS piece that a friend of mine acquired. Hope this helps...
http://www.ccountry.net/~tmobrien/tr...uel%20line.jpg |
![]() Join Date: Mar 2002
You can use steel brake line (NAPA has them premade). Mine was 5/16 for my 305V6. It worked great. Take a metal clothes hanger and bend it into the proper shape (i.e., from the pump to the carb). Cut the hanger the same lenght as the straight pre-fabed brake line and use it as a template. You will need a tubing bender.
1968 GMC 305 V6 3/4 4x4 Stepside 06 Corvette Daily Driver Dallas TX |
