Old 05-14-2004, 03:32 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
Gas tank relocation
OK, so just like everybody here I have the gas tank located behind the seat. I heard a rumor that the pinto's gas tank fits between the frame rails no problem and that the filler neck can be placed behind the liscense plate. Has anybody else moved their gas tank from behind the seat to under the bed. I would be interested in how you did it and around how much it cost.
Todd
toddtheodd is offline   Reply With Quote
Old 05-14-2004, 03:36 PM   #2
Putter
More Cowbell....
Putter's Avatar
Plenty members have moved theirs, but the PINTO part might not be the common link. Most use Blazer tanks. Not saying it can't be done, but that's a new one on me.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-14-2004, 03:41 PM   #3
toddtheodd
toddtheodd's Avatar
where was the blazer tank located on the... blazer?
Old 05-14-2004, 03:44 PM   #4
68 Suburban
68 Suburban's Avatar
Behind the rear axle.
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 05-14-2004, 03:45 PM   #5
68 Suburban
Here is something I have for sale that might work out.
http://67-72chevytrucks.com/vboard/s....php3?t=103954
Old 05-14-2004, 03:59 PM   #6
toddtheodd
toddtheodd's Avatar
that tank looks like it may hit the ground in my truck. I'm giving my rid a 3inch front drop and a 4 inch rear drop.
Old 05-17-2004, 02:18 PM   #7
jpeters79
jpeters79's Avatar
I have 67 chevy and relocated the gas tank between the frame in front of the rear bumper. I then cut a hole in the bumper and put in a flip down license plate for the filler spout. I have a three inch home made body lift on the truck and six inch suspension lift. We used a blazer gas tank, that i purchased from a GM parts store. Check out the images.
1967 Chevy on 1976 3/4 ton Frame with bored over 427. My white beauty.
jpeters79 is offline   Reply With Quote
Old 05-17-2004, 02:49 PM   #8
ryan68
Certified Chevy Man
ryan68's Avatar
I did a pretty custom install of a 31 gallon blazer tank from an 80 Blazer under my 68 longbed. I have a 3/5 drop and am going to a 4/7, and the tank will still be 8-9" off the ground. Check my webpage in my signature for the link the pics and tech.
68 Chevy CST (327,TH400) 3/5 drop lots of fun stuff
71 Suburban 4x4 (350,TH350) 7" lift 37's, D44/14 bolt and other sorts of goodies, lockers front and rear, flexes 40", 895 RTI score
Check out my web site!!! http://www.geocities.com/cst68chevy/
ryan68 is offline   Reply With Quote
Old 05-21-2004, 01:11 PM   #9
Kas68c10
Kas68c10's Avatar
I have a tank that fits tight to the bed, in between the frame rails, hangs down about 3 inches from the frame. I had it reconditioned at Gastank renu,and they stamp it with a lifetime guarantee. My problem was it only hold 12 gallons, which for me wasn't enough. I replaced it with a 20 gallon from a blazer. I am not sure what its worth, if u are interested,pm me, I will take some pics and put a number on it. Oh, I did have to grind the frame about 1/8" to get it to fit. Dont know that it can be f#rd, all the outlets fit the truck.
1968 SWB Stepside, 250,pwr disc brake and tilt pwr steering, 5 spd tranny, HEI,Accel coil,K&N filter,Seat from a later truck with built in seatbelts, front and rear sway bars, moved gas tank to under the bed, headman hedders, new chrome bumpers,one wire alternator,Weber k550cub carburator...WORK IN PROGRESS, Freeland MI , Just bought a 72 Jimmy!!!!!!!!!!!
Kas68c10 is offline   Reply With Quote
Old 05-22-2004, 04:09 PM   #10
toddtheodd
toddtheodd's Avatar
What was the most difficult part of the relocation?
My truck is a daily driver and I need it to get to work. Will this be something I can get done in a weekend?
Has anybody ever tried to put the fill neck behind a flip down liscense plate?
What about the old gas cap location. Did you leave the cap there to look original, or did you guys weld a patch over it?
Old 05-22-2004, 09:16 PM   #11
Spoof
Spoof's Avatar
I'm thinking someone may have been yanking your chain regarding the PINTO gas tank replacement. Pintos were notoriously exsplosive vehicles.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 05-23-2004, 12:23 AM   #12
toddtheodd
toddtheodd's Avatar
only because of where the gas tank was located
Old 05-23-2004, 10:23 AM   #13
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
If you need to do it in a week end then do it except for the hook up and do that on the week end.You can probably do it in a week end but why stress.Mount the tank run the wiring and fuel lines,set up your filler and use the original tank until it's all done and ready to go.Then swap over and go.If everything works then remove the old tank.If something isn't right swap the lines and wiring back and run the old tank until you get it corrected.
What I'm saying is"Always hedge your bets."
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 05-23-2004, 10:32 AM   #14
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Anyone running a fuel cell in the bed or something similar? I am thinking about going that route? Anyone with pics?
thanks
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 05-23-2004, 02:11 PM   #15
Kas68c10
Kas68c10's Avatar
I did my tank in a weekend, but leaving the old one intact is a great idea. I welded a patch over the hole, took the old tank out and put some shelving in there.out of jcw I think.The sending unit was the same resistance, so I didn't have to fool with it. I am not sure about the flip down license plate, I think the plate location in the bumper is too low to fill from. Some one used the tail light and posted it on the board, you can search to find it. More then a weekend job I think. With my stepside, I just cut a hole in the fender. Toughst part ? Filling the hole in the cab, the actual tank switch is easy.
Old 05-23-2004, 02:31 PM   #16
68 Suburban
How are you guys attaching the fuel line to the frame? Do they sell the clips?
Old 05-23-2004, 02:51 PM   #17
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The only way you could have a flip down plate for a filler is if you have the tank hanging down below the frame like in the photo above.
The pinto only blew up becouse the bumper was pretty much the only thing between the tank and the car slamming into it.
Old 05-23-2004, 05:14 PM   #18
67gmcss
I used a summit 16 gal. fuel cell (got the idea off another board member) and the mounting strap kit that they sell with it. I think the part # was like 290100 or something similiar. Just had to take the old tank out of the cab and got rubber fuel line from a local parts store, ran it back to the cell, ran the sending unit line back to the sending unit in the cell and was ready to go. Pretty simple install and plenty of ground clearance in the stock-height 67 step. Just watch out where your exhaust runs out b/c you may have to weld in a plate or re-hang part of your exhaust to keep the two from touching. Hope this helps.
67gmcss is offline   Reply With Quote
Old 05-24-2004, 08:03 AM   #19
Kas68c10
Kas68c10's Avatar
I used a rubber line and zip ties, but they sell clips also.
Old 05-24-2004, 09:39 AM   #20
mustanglx347
I put a RCI fuel cell in my bed 6 yrs ago, but now when it rains, it leaks into the cell at the fill part, and then I have to drain the tank and re-fill it. I am switching to a blazer tank within a few weeks.
mustanglx347 is offline   Reply With Quote
Old 05-24-2004, 10:20 AM   #21
boraxman
Keepin an eye out
boraxman's Avatar
Ok my question is....whats the problem w/ stock tank location? Is it that your riding w/ a bomb in the cab?
As much as I drive my truck(few times a month), dont think I will need to change its location.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 05-24-2004, 03:20 PM   #22
toddtheodd
toddtheodd's Avatar
I'm wanting to put some speakers behind the seat. This is a daily driver for me, and the bomb thing has come up as well.
Old 05-24-2004, 03:43 PM   #23
Kas68c10
Kas68c10's Avatar
I talked to the NTSB bfore I moved mine. It was a daily driver at the time, and my wife was concerned for my son's safety. They had no stats or records that far back. So there were no lawsuits or anything. He said when GM moved the tank to outsde the framerail, they got sued unsuccessfully I think, but they moved the tanks inside the framerail the next year. He thought the inside of the cab had some merit-no rusting or stones,or bottoming out. But if it ever leaked, big mess to clean,and if someone dropped a smoke....He thought if if I got a side impact hard enough to rupture the tank, I would probably be fubarred on impact anyway...but the pasenger may not.They would get nailed in an explsion though.So in my siituation, he recommended moving the tank to be enclosed by the frame as long as it didn't bottom out.
Old 05-24-2004, 05:43 PM   #24
highboy_04
highboy_04's Avatar
i've got a fuel cell in the bed of my truck i'll get some pics of it here in a minute
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 05-24-2004, 05:55 PM   #25
highboy_04
highboy_04's Avatar
the only bad thing about the fuel cell is it only holds 15 gallons and there is no sending unit so i dont have a fuel gauge. i have to just keep checking.
'67 c10 350/th350
