Old 05-14-2004, 09:11 PM   #1
shavedchevy
shavedchevy's Avatar
I found "THE" engine
checked out Jegs the other day and they added this crate engine to their line. Not bad for a 383....eh
Horsepower: 425 @ 5400 RPM
* Torque: 460 lb-ft @ 4500 RPM
* Compression Ratio: 9.7:1
* Block: Cast Iron, 4-Bolt Main, 1-piece rear main seal
* Crankshaft: Forged 4340 Steel, Externally Balanced
* Connecting Rod: Powdered Metal (Special ''383'' Version)
* Pistons: Hypereutectic Flat top with offset pins
* Camshaft: hydraulic roller, 222°/230° @ .050'', .509''/.528'' lift, 112° centerlobe
* Cylinder Heads: Aluminum Fast Burn 62cc chamber, 210cc intake runners, 2.00'' hollow stem intake/1.55'' sodium filled exhaust valves, LT4 Corvette valve springs and lightweight retainers, D-shaped exhaust ports and dual bolt pattern intake manifold and valve cover configurations
* Rockers: 1.5:1 Aluminum full roller, self-aligning
along with a stage 3, 700r4 and a lim slip and I'll be set...... Oh yeah I need money. I better get a good paying job this summer. Donations are welcome also
Dennis
shavedchevy is offline   Reply With Quote
Old 05-14-2004, 09:15 PM   #2
gldevall
gldevall's Avatar
That pic is not the 383. That's the 572 big block.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 05-14-2004, 09:21 PM   #3
shavedchevy
Yeah I know. I figer they would look the same anyways, or close to it
Dennis
Old 05-14-2004, 09:23 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
Yeah, I was getting ready to say, that ain't no small block.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 05-15-2004, 02:50 AM   #5
75-K5
Bucket of Bolts
What kind of price are we talking for this powerplant?
This is the project that never ends, yes it goes on and on my friend....
75-K5 is offline   Reply With Quote
Old 05-15-2004, 07:31 AM   #6
TIMSPEED
TIMSPEED's Avatar
Personally, I'd rather Have the 350 H.O. with a XE274 cam swap and uprgraded valve springs. THAT (in 350cid) would perform aswell if not better than that, for less money.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-15-2004, 11:07 AM   #7
shavedchevy
The 383 is about $4600.... while the big blocks 620 HP and 720HP are about 15,000 and 16,000 respectively
Dennis
Old 05-15-2004, 07:52 PM   #8
low 84
low 84's Avatar
hows a cam swap gonna give you close to 100 hp and 80 ft/lbs? i think i'd much rather have the 383. the more cubes the better
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 05-15-2004, 09:04 PM   #9
Tom
driving is in my blood
Tom's Avatar
You are posatively insane to pay $4600 for a 425hp 383. I could build that power and reliable of a 383 for $2500.
Old 05-15-2004, 09:20 PM   #10
shavedchevy
Oh, I'm sure anyone with a good mechanical backround could built one for cheap..... but I'm what they call...... DUMB when it comes to this kinda stuff. Throw labour on top of the parts and I figer it's a pretty good deal for not knowing much. I could probly throw it in a truck but that would still take some learning for me.
Dennis
Old 05-17-2004, 03:39 PM   #11
trixter99
I have no time for this
trixter99's Avatar
yuo should give ProStock in Edmonton a call i'll bet they can give a good price and since your pretty close you won't have to pay all that shipping and put the money towards other parts.
1986 Chevy short box ( PROJECT )
1994 Chevy Blazer lifted 6"
2009 Gmc 2500 HD
1999 Hugger orange Camaro SS
2007 BMW X5 Sport
trixter99 is offline   Reply With Quote
Old 05-17-2004, 06:11 PM   #12
shavedchevy
Hey thanks alot TRIXTER99. I'm only about 1 1/2 hrs away after I move to my new place. That would sure work out good.
Dennis
Old 05-17-2004, 06:32 PM   #13
Joey-D
City's Articulation Ramp
Joey-D's Avatar
Check out www.larrysperformance.com. Thay quoted me a 383 shortblock running 10:1 forged TRW pistons fully assembled, balanced and blue printed shipped to my house for $1500. Now you take that 383, have larry's throw some big ol' afr heads on there and a holley double pumper, you now have a motor with about 100 hp/ 100 ft lb more power for less that that 4600. Can't beat that!
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
