05-15-2004, 12:58 AM | #1 |
computor placement
With an AC cab- where have you guys mounted your TBI computors and still got the harness to fit?
05-15-2004, 11:51 AM | #2 |
No one? Guess I'll have the only tbi big block in a 68
05-15-2004, 06:38 PM | #3 |
The TBI computers must be mounted in a water tight location. The later ECMs 96-up can be mounted any where under the hood.
95 K3500 SRW 5.7L Vortec 4L80e 4.10 G80 2001 GMC C3 6.0 AWD, Volant, 3/5 drop TBSS intake, HP tuners, pullies, 05 efans, 05 front brakes, etc. 2003 Tahoe Z71 Silverado front clip |
05-15-2004, 07:59 PM | #4 |
Fortunatly I don't have AC to contend with when I mounted my ecm and new circuitry for the tbi setup. If you have enough wire sitting around you would extend it back under the seat. Or, do some work with the glovebox
There's enough room under the dash and above the fuse block but you'd have to make up a set of brackets for it and still extend the wires possibly. |
05-15-2004, 09:43 PM | #5 |
I mounted mine under the glove box (it'll interfere with the shape of the cardboard somewhat but I'm not too worried about it). Used two pieces of aluminum. Mounted one end of each to the firewall (between blower motor and heater core) and the other end to the bottom of the dash below where the glove box hinges mount. I'll get a pic of the inside of the glovebox if you want.
Here's a pic(sorry for bad quality) showing where I drilled the hole for the wiring to come through. You can also see the two phillip head bolts between the blower motor and heater core, each holding one bracket on the inside of the truck. Not sure exactly what the differences are with an A/C cab. I'm sure you'll be able to get something to work... Time to get creative
Tom 1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes. |
05-16-2004, 12:24 PM | #6 |
Thanks for some of the ideas
05-16-2004, 12:56 PM | #7 |
I don't have AC but I mounted mine in between firewall and heater box, I think my Holley Commander 950 is smaller than the GM Box as well.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
05-16-2004, 10:04 PM | #8 |
I saw an old hot rod in Orange, where the guy fab'd a box into the inner fender. Looked nice and clean.
'72 C-10 w/ '68 Large Journal 327cu.in. "It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie" |
