As the title reads I need some info on a 1965 C10 disc brake conversion. I have seen many sites that sell the kits with all the necessary parts. Just wondering if there is other cheaper routes to make this happen?
Thanks in advance Last edited by 65C10Chevy; 05-15-2004 at 02:18 AM. |
Registered Smarta$$
have you thought about get some 71-72 chevy setup it should work
Unending Project
What's the story with using 71-72 chvy crossmembers? are they a bolt up application for our years? If not, what needs to be done & changed?
Piper |
71-87 will mostly bolt in.you must also use the steering linkage from the same truck.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
