I was stopped in "D" yesterday and I could hear a light, metalic scraping noise from under the cab. I put it in park or neutral, it stopped. Any gear foward or reverse, I hear the noise, but only at a stop. As soon as I start rolling it's gone. So I get under the truck and I can see two problems: First there is no cover over the torque converter- there's supposed to be one, right? Second, I can see an uneven row of little knicks on the torque converter. What's up here? I haven't enrolled in the transmission class yet so I have very little experience here. Makes me shy about drining the thing at all. Appreciate some help ASAP!
Thank you.
My son, my joy.
Well, I've been running without that cover for years now. I was too lazy to put it back on and now I think I've lost it.
But, anyway. Maybe you got something stuck up in there? |
i haven't run a converter cover in years also, check to see that the bolts going thru the flexplate(flywheel) into the converter are tight and also the bolts holding the tranny to the engine are tight
Because of the irregular pattern, I'm inclined to think a bolt got loose or I picked up some debris.
I'll look. Thanks
On the road
![]() ![]() Join Date: Jan 2004
You may want to check the flexplate also. I have seen them crack around the mounting bolts where it attaches to the crankshaft and also where the converter bolts to it. Usually it will make more of a knocking or rattling sound but it can cause the converter to not line up properly in the front pump bushing and make funny noises if it's cracked around the converter mounting bolts. Not easy to check, and it's hard to see up in there but worth a shot. Unbolt the converter, slide it back and get a flashlight and mirror roll the engine my hand and give it a good look see.
#6 | |
Bloo
ive got the same problem on my th350 in the 69!! if you find out what it is, let me know please!
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
#7 | |
Time for a new tranny
Thanks.
![]() ![]() Last edited by Zonaman; 05-19-2004 at 02:07 PM. |
#8 | |
On the road
If you have a tilt column you can use the indicator that Flaming River puts in their tilt columns. Those columns look like an exact copy of a truck tilt and they offer them with an indicator for OD. My buddy 65streetcruiser put a 72 tilt column in his 65 and a 700R4. He ordered an indicator from Flaming River, on the box is written Part No. FR20010LNO. It bolted right in and looks stock except it has a position f/ OD. Don't know about the non tilts though, they are different. Mike |
