upper moulding clips
has anybody ever had any luck with these aftermarker upper moulding clips?I bought a complete set from a vendor here on the board,that is very reputable,and either im not doing something right or these have got to be the biggest piece of $hit things i have ever seen.The push in ones dont even hold,they just pull right back out.And ive broke like 5 or 6 of those tiny wires off of some.What the hell is the deal?Does anybody sell a set that is worth a crap?I dont mind buying some if they work.Dammit this has me pissed off.
he who dies with the most toys wins... |
or better yet,if somebody has bought a set and they actually worked,please let me know.I know LMC carries some and im sure a few other vendors do too.I broke enough of these that i have that i am gonna have to buy another set now anyways
ttt................
Thats the Hillbilly way
Mike : you are not alone ,as I mentioned in my post on BB , the upper molding kit I got was the pits ,almost every spring broke when installing the clips and the pushin
![]() I went to the Truck Shop and got their clips and pushins worked great.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
can you buy those online?
If this link doesn't work it's on page 84 of their 67-72 chevy truck catalog.
http://www.truckandcarshop.com/60_72/066-085.pdf
ok,thanks ....ill go look.Who would you reccomend ordering a few(12) of the lower trim clips?The ones that have the nut on the back.I know LMC looks like they carry them but they are 3 or 4 bucks apeice.Did you have to buy any of those?
ok,i checked out the site....and im guessing you bought the set that is on the top of that page where it says the "push in clips" right?And these are the push in kind because i didnt see any in the picture?
The trim clips that came with my lower trim were ok ,I only had to get a couple of pushin one's .
Truck Shop also sells the lower clips on page 86,the pushin and screw one's are ok ,don't get the adhiesive one's.
so,on the ones for the upper trim,in the catalog,if it says they are push in,thats what they are right?Im like you,i dont want the adhesive ones
#11 | |
brb..............
#13 |
Keepin' It Stock
I went a different route when I put the trim on my truck. I purposely didn't go with the push-in clips. When I had the truck painted I made sure to get good paint coverage in the trim holes as they are prone to rust. So, I didn't want to scrape off the paint with the push-in type clips. I used the screw-type clips on the upper trim where I could get to the nuts. I could get to all the nuts on the fender moldings, except the one nearest the door. I could also get to the nuts on the cab corner trim on the passenger side. I couldn't get to the one's on the driver side cab corner because the gas tank filler neck was in the way. Of course you can't get to any of the bed trim nuts. Where I couldn't get to the nuts I used the adhesive clips. For some reason the adhesive clips have gotten a bad rep but I haven't had a single problem with them in over 2 years. Also, they cause the trim to stand proud of the body by about 1/32" which lets any moisture that gets under the trim to quickly dry out.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
#14 |
I didn't like the new clips much either. I have some NOS GM moulding here though and it has the same crappy clips. Nothing like the originals. I used most of the originals and then used all of the stick on clips for the top trim. Stick ons due make the trim stay out from the body a bit.
"Repo parts......why can't they spend a few extra minutes and make it exact" |
#15 |
where did you guys get the sticky ones?
#16 |
Red
Here is another option to consider: http://67-72chevytrucks.com/vboard/s....php3?t=100130
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
#17 |
thanks....i have a small roll of that too....guess i can give it a shot....i hate to spend any more money on something that still wont work
#18 |
Keepin' It Stock
The adhesive clips I used came with the trim set I bought from Kings Parts. I'm not sure if he sells them individually. He's listed on the Board's Parts Supplier page but I noticed the link didn't work, so I don't know whats up with that.
#19 |
check these out...
