Old 05-15-2004, 09:01 PM   #1
60apache4
Full floating axle wheel bearings
I am almost done with the brake swap on my 71 K20. Do I need to pack the wheel bearings in the drum/hub with grease? I believe they get lubricated with gear oil via the differential and axle tube as there is no seal in the axle tube and they are splash oiled with the oil slingers...Thanks...Tom.
60apache4 is offline   Reply With Quote
Old 05-16-2004, 01:21 AM   #2
sakohntr
sakohntr's Avatar
lube
I have heard that from other people as well concerning greasing the bearings. They are oil bath bearings and hence do not require grease. I usually make it a point to jack up one side at a time and wait, to make sure gear oil gets down to the end of the tube and submerge the bearings prior to take off. If i was putting a vehicle in storage for an extended period of time it would be a good idea to pack em with grease though. Good point to bring up.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 05-16-2004, 12:49 PM   #3
60apache4
Thanks Bruce, that's what I thought. I went ahead and soaked the bearings in gear oil and "injected" more gear oil into the hub recess.
