Old 05-15-2004, 09:58 PM   #1
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
front driveshaft u-joints
Pulled my front driveshaft today to replace the u-joints. Any tips on replacing the u-joints in the double cardian end? Does the "centering ball" and associated parts need to be replaced? Thanks!
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 05-15-2004, 10:34 PM   #2
DINS 1
DINS 1's Avatar
you should replace the center ball. there is a kit for it. those joints are a pain to get all the parts apart and back together. if you are good at standard u joint then all you will need is some time and you can get the the double joint and center ball all changed out
Wade
"DURAMAX BURB" Burb on 2004 chevy 2500HD 4x4 Duramax chassis Long term project
2004 2500HD 4x4 crew cab GMC Duramax 4" lift 35's
79 RS Camaro
DINS 1 is offline   Reply With Quote
Old 05-16-2004, 12:08 AM   #3
1969 GMC
1969 GMC's Avatar
Thumbs up
Agreed. It is pretty easy to do, but can take a while. Good luck
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-17-2004, 04:46 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
I'm calling NAPA today. Thanks!
Old 05-19-2004, 08:03 PM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
OK. I got the 3 joints and took the u-joints/double cardian apart. It looks like there's a bearing and a seal, it also has a grease fitting. The seal is gone but the bearing had grease. Which part exactly gets replaced/rebuilt? There's the welded on yoke and the yoke that has the ball which has the bearing and grease fitting. Also there was a little spring that was broke in two pieces.
Old 05-19-2004, 09:42 PM   #6
LONGHAIR
There should be a kit for the Constant Velosity joint. It will give you those parts. There is more to it than just the joints...........as you have found.
LONGHAIR is offline   Reply With Quote
Old 05-20-2004, 06:11 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
something else: The u-joints, while all spicer 1310 type, have different NAPA P/N and the only difference I see is the grease fitting. The two for the double cardian (379) have the fitting coming out of the center at an angle while at the axle end (369) the grease fitting goes straight in the center. Also I marked the H-yoke but it appears to go either way. If I buy the centering yoke do you think it comes with the small parts?
