05-16-2004, 12:43 AM | #1 |
Garage Queen Material
tell me about th375 trannys
tell me all you know about them.
it looks like my dad has one of these instead of the original th400 that we thought he had. he just bought a nice new expensive lokar shifter and it wont install because the tail housing is different and it is printed 375th on the tailshaft. |
05-16-2004, 01:52 AM | #2 |
something along the lines of a TH400 case with TH350 internals and tailshaft or vise versa i believe...
Daily Driver: 1992 Blazer dropped on rallys Project: 87 GMC shortwide, About to get a little boost |
05-16-2004, 09:10 AM | #3 |
Ob-Gyn Kenobi
found this...
TH-375 A medium duty version of the TH-400. On the underside of the trans, right where the tail housing bolts up, the letters "TH-375" can usually be found cast into the trans housing. Pan Shape A TH-375 pan is the same shape and size as a TH-400. Olds TH-375 ID's: ID Year(s) Application OA '73 2V 350 88 OA '74 4V 350 88 OA '75 350 88 OB '75 350 88 (Calif) OE '75 400 (Pontiac) 88 (exc Wagons
'85 GMC Shortbox... I used to have a firm handle on life....then it broke off. |
05-16-2004, 11:29 AM | #4 |
I was told it is a TH400 with a shorter tail shaft. The B&M shifter I installed used the TH400 bolt pattern.
Boyd
79' C10 Short Step 355/TH375 W/3.73 & Eaton Posi 1.5"/3" Drop What I have I owe to udders! |
05-16-2004, 11:37 AM | #5 |
When I had my TH375 rebuilt, the guy that did it used all TH400 internals for strength. So you can pretty much build a TH400 out of a TH375.
