Garage Queen Material
what tire size?
i wanna get some nitto 555's for tires...
but would a 255/45/17(fronts) and 275/40/17(back) look to small on only a 4/6 drop? i wanna drop it down and make it a 5/7 drop later on(this year maybe?) i only have 2 tires for my 17's right now, and they are 275/50/17's. i would use those for a while till i could afford matching rear tires. or i could get the nitto 450's in the following sizes: 255/50/17 275/50/17 |
Eric, your not gonna' like this but IMHO the 275/40/17 is just too short for a full size truck.
If you want, in the morning I can get some pics of some take-off 275/40's up against my beaters 255/70/15's & my 74's 295/40/20's so you can see just how much shorter they are. That size is fine on my GF's T/A, but not on a truck.
when i had my 17's i had 275/40 on front and 285/40 on rear, i agree with scoti, they were a little too short in my opinion. they still looked pretty good with a 5/7 but with an inch more of gap like you will have i think they would look wrong. if i was getting another set of 17's i'd go with something around 27-28 inches tall, not 25-26
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#4 | |
275/40r17 are not to short, my are just fine, they sit at about 26'' tall
1982 chevy C-10, blue 2wd shortbox 17x9 cragar ss rims, 350V8-th400 2003 suzuki gsxr 1000-hit 175mph!!! yeah it's fast-no you can't ride it |
no, they dont look bad, but they do have more wheel gap than what i would like.
how low is your truck odie? |
![]() Join Date: Apr 2004
Does anyone know of a site that you could type in a tire size and it will tell you the overall height?
You get what you pay for
![]() Join Date: Dec 1999
Here's one.
http://www.miata.net/garage/tirecalc.html Here's another page of useful info. It will let you use a calculator to figure out a lot of stuff, including tire diameter. http://www.73-87.com/convers_calcus/equation1.htm
Mike 1985 Chevy C-10 |
paper or plastic?
I've got 275/60/17 on the rear of my truck with a flip kit. They are about 30" tall. I think they look better with a little meat (sidewall) on them .
GrandeRojo.... that looks sweet.
man, if i get those nitto 450's in the 255/50/17's, thats ONE MORE thing that i'm coping off of mike.
well, i had the flip kit first mike!!! only reason i was asking about the lo-pro tire size was because i was wanting to run some nice drag radials(nitto 555r's) and they dont come in anything bigger. |
Why drag radials? These trucks have enough room to run meat.
#13 | |
