Old 05-16-2004, 01:43 AM   #1
wxman1
Whistle for TDC
I think I read something about a device which screws into the #1 plug hole
and it makes a whistling noise as air is being forced out of the cylinder as you
turn the crank by hand. It supposedly changes pitch the instant air stops being
pushed out of the cylinder to air being sucked into the cylinder. Such as when
you pass TDC with both valves closed. It was supposed to be very accurate.
But, I can't remember where I heard about this device. Anybody ever heard about
this thing or know where you can get it?
Jim
Mt Juliet
wxman1 is offline   Reply With Quote
Old 05-16-2004, 01:59 AM   #2
jescates
jescates's Avatar
I seen something on them a few years back, you might try JC Whitney, they seem to have the off the wall stuff. You can always have someone bump the ignition while placing a finger or thumb over the number one. You should be able to feel the air push out and that will be top.dead.center. Good luck. Jay
1970 C-10 LWB
1998 Jeep Wrangled TJ
2009 Honda VTX 1300
2013 Buick Enclave
jescates is offline   Reply With Quote
Old 05-16-2004, 07:30 AM   #3
7T1BURB
Eastwood...
carries this type of TDC "finder" (Item # 46048). Purchased two years ago and have used it on 3 engine rebuilds to determine TDC when timing/tuning. Works great and will continue to use on future rebuilds and tuneups. Cost is around $23.00 (dual thread pattern of 14mm and 18mm and a 22" attached hose). Additionally, they also sell a 14mm "long reach" extension for about $5.00.
Hope this helps!
Thanks...7T1BURB
7T1BURB is offline   Reply With Quote
Old 05-16-2004, 10:32 AM   #4
68C15
blood type; Retumbo
68C15's Avatar
if you have a Cornwell dealer in your area they sell them. bought one a few years ago & use it a lot. dont remember $ but whatever it is it is well worth it.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 05-16-2004, 02:07 PM   #5
72c10step
WHYBYNU when old will do?
72c10step's Avatar
You can get one at Eastwood company. Check here
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
