Old 05-16-2004, 09:27 AM   #1
veltex
veltex's Avatar
early 65 396
This may be the wrong board but since it was in my truck it kind of applies, switching from 396 to 454, just to start over, the thing is the 396 which runs fine turns out to be a March 1965 block, not the high horse version but just a 325hp, does this have any more value than the run of the mill BBC? Any thoughts on value for running core long block? I probably will keep it for a while, but may sell. thanks all
beater 65 gmc at the moment
veltex is offline   Reply With Quote
Old 05-16-2004, 10:17 AM   #2
Bowtie67
Bowtie67's Avatar
It probally does, There wasn't to many things that had the 396 in them in 65 and I beleive the first year of the 396 was in 64, If your switching the engine only because it was rated at 325 horse all you need for that is a better cam like the 390 horse cam from a 427. I would think it would get far better gas milage than that 454 your thinking of putting in. JMO
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears
1948 Chevy FleetMaster Coupe, LS1, (almost done)
1950 Chevy StyleLine Coupe 250/6 3x2 Dueces
2009 Toyota Tundra
1996 Harley RoadKing
"I maybe getting old, but I can still burn rubber with the best of them"
Bowtie67 is offline   Reply With Quote
Old 05-16-2004, 12:00 PM   #3
veltex
veltex's Avatar
thanks, unfortunatly it isnt about mileage, its about towing, and starting with a fresh motor that I know the details of, and that I can count on for several years (no flat cams!!), I dont mind having an extra motor lying around, this 396 was in a passenger car with an automatic, I figure its got to be an SS Impala, but who knows? I dont think production cars had a 396 until 65, but I am no expert maybe someone who is can help here.
Old 05-16-2004, 12:01 PM   #4
veltex
veltex's Avatar
Oh, and also its too late, 454 is in and should be on the road by tonight if all goes well, yee haa
Old 05-16-2004, 12:58 PM   #5
Olden Days
Living In The Past
Olden Days's Avatar
I know they were in some "rare" 65 chevelles too. I would guess that motor would be worth a lot to the right person. I also believe 65 was the first year in production cars.
Olden Days is offline   Reply With Quote
Old 05-16-2004, 01:10 PM   #6
72C203503ONTHETREE
72C203503ONTHETREE's Avatar
The only cars that got the 396 were the Vette and ther Z16 option Malibu SS, and halfway through the year the Impala SS got it, which yours is I'm sure. The early Impalas still came with the 409. If your 396 has an iron intake and Q Jet its a Impala engine. The Vette and Malibu 396 had the high rise dual plane aluminum intake. Still a good engine though, keep it. No cars had the Mark IV big block until 65. Chevy did try running it in 64 in a race car and was called the mystery motor. If you get a cam for the 396, make sure you get the correct version. The 65 and 66 big blocks used a different cam than the following years, the rear cam journals are different. If you put a newer style cam in, you will need to install a rear cam bearing for a 67 up engine, then it will be fine.
72 Chevy C20, SOLD (Dang it.)
09 Challanger RT six speed in all black.
74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power.
73 C10 long bed, 350/350 combo, nice shape.
72C203503ONTHETREE is offline   Reply With Quote
Old 05-16-2004, 02:44 PM   #7
Pont
I need another Barley Pop
Pont's Avatar
72C203503ONTHETREE is right on the money to the best of my knowledge. However, not all Malibu SS 396's had the aluminum intake. I have a 396 out of a 66 Malibu SS that has a factory iron intake that is not the spreadbore design. It's a square flange for the Holley and is stamped "Holley" on the intake. All in all, that engine is worth some money, definitely to someone wanting to restore a 65 Chevelle SS.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
