Old 05-16-2004, 04:57 PM   #1
our64
http://public.fotki.com/street
our64's Avatar
Door Lock
Can anybody tell me how the driver door should lock. If i close the door and lock the push button with the key, all is well, but if i lock it from the inside lever and close the door, im screwed..Nothing will open the door, have to use a coat hanger to break in....Is this right
our64 is offline   Reply With Quote
Old 05-18-2004, 10:03 PM   #2
kennyw
N9PHW
kennyw's Avatar
No, the inside door handle should pop out of the lock position when closing the door. Not sure what you need to replace but something isnt working right.
"I got it one piece at a time and it didn't cost me a dime..."
kennyw is offline   Reply With Quote
Old 05-19-2004, 09:33 PM   #3
Shorty Cox
Kenny is right, One can not lock the doors on a mid-60's truck by pushing the inside handle and closing the door. One has to use the key, unless you stay inside.
Shorty
Shorty Cox is offline   Reply With Quote
Old 05-19-2004, 10:14 PM   #4
cochran63
cochran63's Avatar
I had the same problem with my 63. I had to bust my vent window out one time. The only solution i found was to only lock the door with the key.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 05-20-2004, 01:59 AM   #5
Chevyboy1962
C10 now is a GMC
Chevyboy1962's Avatar
I just fixed mine. The spring on the door regulator is either broken, or is sprung. I got tired of breaking in the vent window, and barely shutting the drivers door so it wouldn't lock me out, so I welded the spring perminately to the regulator. It's like new now.
*1962 C10 swb fleetside, big window, custom cab 350/TH350 combo...Hot Rod
*1963 C10 lwb fleetside, small window 230/4 speed...Blvd Cruiser
*1931 Ford 5 window coupe (soon to be Hot Rod)... Father & Son project
Chevyboy1962 is offline   Reply With Quote
