Old 05-16-2004, 07:28 PM   #1
guyryan100
guyryan100's Avatar
Build my new engine
About to buy a crate engine - what to look for? Will be a 350 for sure and am looking to end up with a daily-driverable truck with a little bit of get-up-and-go but not sacrificing a lot of fuel economy. Will have a 700R4 tranny. Money is definately a factor too.
--Ryan
guyryan100 is offline   Reply With Quote
Old 05-16-2004, 07:42 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
depending on your definition of get up and go...the low priced 300 horse 350 is a pretty cool motor. I think that's what Huck has in his truck, and when i drove it, i was kinda surprised at the low end grunt it had. Some of that may have been the 5 speed it was mated to, but I think it was a pretty good engine for a driver.
Old 05-16-2004, 09:35 PM   #3
Stroker
The 330 HP GM would probably work well for you. With the delux all you need is your exhaust and possibly a little work to get the linkage for cab and tranny ironed out and your set. http://www.gmpartsdepot.com/store/pr...Product_ID=963
If your budget is a little less than the 330 hp engine and you already have a conventional bolt pattern intake and carb this might be a better deal for you.
http://www.gmpartsdepot.com/store/pr...roduct_ID=1835
72 SWB parts and pieces
Oklahoma
Stroker is offline   Reply With Quote
Old 05-17-2004, 08:36 AM   #4
guyryan100
guyryan100's Avatar
I ran across that same 330 HP motor and since I'm replacing a 250 I will need the intake and carb, so this is a good setup. One thing I'm not sure of is the factor that determines the fuel octane required - I noticed that as the horsepower increases there comes a point where 92 octane is required - is this based on compression ratio? Is there a rule of thumb here? I would prefer to burn the 87 octane if possible.
Old 05-17-2004, 03:54 PM   #5
chevytruckfan
chevytruckfan's Avatar
yes it is based on CR. The higher octane helps prevent autoignition or knocking in high compression engines. Stay under 10.5:1 CR if you want to stay on 87 octane. Any higher Compression and you will have to increase your fuel octane. As for a rule of thumb <10.5:1 87 octane, 11:1 89 octane, >12:1 92 octane.
chevytruckfan is offline   Reply With Quote
