Old 05-16-2004, 11:33 PM   #1
Jefe
Jefe's Avatar
Truck 4 speed to car 4 speed..
Thinking about taking out my truck 4 speed in my white 68 and putting in a muncie. What I'm wanting to know is are the splines on the in-put shaft the same from the truck 4 speed to the muncie?....can I use the same clutch? Thanks!!
Douglas.
-1968 Chevy SWB = Frame Off/383/Muncie Car 4 speed
-1968 Chevy SWB = numbers matching 307/Truck 4 speed.
-1966 Chevy II = 2 door No Post/130,000 Orig miles/230 6cyl/powerglide/Vintage AC
-1972 Chevy Nova = 2 door/412 Small Block
-1927 Ford Roadster = Homebuilt/widened 8"/350/ Custom Everything.
Jefe is offline   Reply With Quote
Old 05-17-2004, 10:30 AM   #2
Fast67velle
Originally Posted by JimKshortstep4x4
The course splined Muncies will fit the clutch splines on your truck. The fine splined Muncies like the M-22 will not fit unless you change the disc.
Jim
Not all M22's were fine splined. Also, 71-72 Muncies had fine input and large fine output, but they weren't M22's, they could be had in M20 and M21 versions.
What was the 4-speed that is coming out of your truck? I am guessing a Saginaw. It should be direct bolt in. You will have to change your shifter linkage though, that will not bolt up.
WANTED: 55-75 Muscle Cars, Classics, and Parts in any condition
http://www.freewebs.com/fast67vellen2o/index.htm
67 Chevelle, sbc, 4 gear, bottle, how fast can it be?
Fast67velle is offline   Reply With Quote
Old 05-17-2004, 02:09 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Just a side note......
If you don't already have a Muncie, be prepared to shell out some cash for one. I saw some at a local swap meet a couple weeks ago and they were going for at least $500 for a complete used one (not rebuilt).
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 05-17-2004, 10:06 PM   #4
Jefe
Jefe's Avatar
Already have a close ratio mucie in my black '68. Got it for 400 bux rebuilt. I know a good source on them so that's not a problem. Thanks for the help guys!!
Douglas.
