Old 05-16-2004, 11:45 PM   #1
low 84
low 84's Avatar
anyone switched to a 4 spd?
has anyone on here switched their truck from an auto to a manual? its not something i would be doing anytime soon. but it is just something i was thinking about doing down the road. i'd like to go to put like a close ratio muncie in it, i even have a buddy that has what i think is one sitting on a shelf in his garage.
i don't know much (anything is more like it) about setting up manuals. so what all is involved in switching over? how hard is it to set up the clutch/pedel in a truck that was an auto? what else do i need to think about?
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 05-16-2004, 11:57 PM   #2
ocbaud
Garage Queen Material
i would get a stage 3 turbo clutch pack and heavy duty thruster pivots to compensate for the low abridged force caused by the disengaging of the stage3 clutch.
ocbaud is offline   Reply With Quote
Old 05-17-2004, 12:05 AM   #3
1FaastC10
1FaastC10's Avatar
Eric, STFU.
im switching to a hydraulic clutch setup in my 86. the main reason for going hydraulic in my case, is that the manual linkage likes to bind when the truck is flexed out. since your truck wont ever be flexed out, you should be fine with a mechanical setup. i just removed a mechanical setup from my K30 today. from the way it appears, bolt in the clutch/brake pedal assembly, cut one hole in the floor for the linkage to go through, and install the Z bar. and of course, a hole in the center hump for the shifter. dont see any reason why it would be a bolt in, considering these trucks came with manuals as well as autos, so stuff should pretty much be bolt in.
1FaastC10 is offline   Reply With Quote
Old 05-17-2004, 01:47 AM   #4
low 84
low 84's Avatar
so the clutch pedal and break pedal are part of the same assembly in manual trucks? i probly sound like an idiot but i have never worked with any manual trannies so i don't know how anything hooks up. its sounds easier than i was originaly thinking.
if i got a the clutch and break pedal assembly along with the mechanical linkage, would all that stuff hook up to a muncie trans?
'05 1500 Crew Cab
RIP
Old 05-17-2004, 01:58 AM   #5
Russell
Professional Grade
Russell's Avatar
Does the clutch and brake pedal simply unbolt? Didn't appear to be the case in my 76... Looked welded to the dash support.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 05-17-2004, 02:23 AM   #6
Dwaynes56&68
The whole pedal assembly unbolts. I switched to a 4 speed/205 transfercase and it was a near bolt in deal. Had to cut a hole for the clutch rod thats about it. Go to the junkyard and mangle a parts truck for the things you need. Then when you go to work on your ride, you know the in and outs.
Are we there yet?
Dwaynes56&68 is offline   Reply With Quote
Old 05-17-2004, 11:51 AM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You will need EVERYTHING from the donor truck. Don't forget to get one of these:
It is the mechanical Z-link locator for the frame. Pedals will remove, you just need to take the nuts off the outside of the firewall (with the brake master cylinder). Brake/clutch comes out together. A bellhousing from a 3 speed will work also.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 05-17-2004, 03:30 PM   #8
low 84
low 84's Avatar
cool, thanks guys. i was thinking it was gonna be alot harder than that but it looks pretty straight forward. now i just need to get the #'s off the tranny my buddy has to see which muncie it is
'05 1500 Crew Cab
RIP
Old 05-17-2004, 05:25 PM   #9
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Ryan I've got an exploded view in my 79 Gm shop manual of the linkage etc. if you need it.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 05-17-2004, 11:41 PM   #10
jimfulco
If you have 2.73 gears, you will not like the Muncie 4-speed. It will be a PITA trying to get it to move from a standing start. You'll be slipping the clutch so much it won't last long at all. This would be an exercise in frustration in a 3200lb Nova with 26" tires & a 350 (mine had 3.08's & was fairly bad), much more so in a truck with taller tires, more weight, & a 305. The close-ratio Muncie would be worse than the wide-ratio, but neither would be pleasant to drive.
jimfulco is offline   Reply With Quote
Old 05-17-2004, 11:52 PM   #11
1FaastC10
1FaastC10's Avatar
his truck has 26" tires, and there's no 305 anywhere near it. if im not mistaken, the 3.08s are temporary too.
Old 05-18-2004, 11:59 AM   #12
PHOENIX
His sig is rather old
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 05-18-2004, 03:58 PM   #13
low 84
low 84's Avatar
the sig is pretty new, i just made all of it up
5/4 race cams.............
'05 1500 Crew Cab
RIP
