Both windows go up and down very hard...how to fix???
On my new 71 K-10, both windows are VERY hard to crank up or down. What could be the problem? Is something worn out or does it just need a little WD40? Thanks!
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 |
![]() Join Date: Feb 2001
WD works wonders for lots of things.........
![]() or......some white grease on all the pivot points or the regulator and gear... |
Yeah, just remove your door panel and lube up the rollers, track and the scissor lift inside the door
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
![]() Join Date: Dec 2003
I tryed that very same thing on mine and it made it a little better but not totally (i still have to use my other hand to help the window up) is there aything else you can do??
https://www.ebay.com/itm/29620574751...mis&media=COPY |
Try spraying silicone on the window tracks (channels).
if cleaning and lubricating the mech doesn't work about the only option is to change out to new parts
67-72 Addict!
I thought you had to get ALL the old grease first then apply new grease.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
I had this same problem on my 72 GMC. I was going to replace the regulators, which seemed like the logical choice.
After I got the regulator out (which is not the easiest task in the world), I noticed that there was a lot of rust on the slides that all of the grease in the world was not going to help. After a lot of elbow grease and sandpaper and emory cloth, my regulators now move with ease. It took some time to complete, but it did not cost me anything. HTH. |
71 DELUX
WD40 warning!
WD40 is great, but not what you want to use on the regulator. I put some on the regulators of my 1955 F-100 and then I could no longer keep the windows in the "UP" position. They were so lubed and free, they'd rattle down into the door with simple (albeit straight-axle) driving!
I'd say clean the channels very well, get into the door and re-grease the regulators. Just my two cents... |
its all about the +6 inches
WD40 is worthless, and induses rust. PB Blaster is a cheap and much better spray lube.
I removed mine, hosed them down with brake clean, then soaked them with PB Blaster. These things roll up and down like a new car...actually easier than my wife's 76,000 mile kroger cruiser...without the "too easy" thing as described above. If they roll down too easily, then you basicly need a new regulater, the spring is probably broken. |
Is there any easier way to get all that stuff out of the door (my arms are too big to move around inside the door!) I can't even see the other side slide channel. are thier some special tools or something i am missing out on?????
ttt.........
#13 |
Check out this older post, Bow-tie-bandit had a step by step that should help.
http://67-72chevytrucks.com/vboard/s...threadid=82235 Last edited by A few 72's; 05-19-2004 at 01:35 PM. |
#14 |
Make sure nut tn is broke!
Clean em first with something Castrol degreaser is a good product! Then oil em up add some grease here and there and BAMM!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#15 |
Also make sure the three nylon rollers are in good shape if not replace them while you have the regulator out. I know most of the ones in my truck and the burb were worn out or gone.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
#16 |
On mine, there was a flat spot on the nylon roller. I ended up replacing the whole assembly.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
#17 |
Three words: White Lithium Grease. Work at a body shop and that stuff is perfect for that kinda stuff. If that doesn't help try loosening the regulator and adjusting, if that doesn't work, the regulator probably has a little of the rusty stuff in thereand needs replaced.
Hope that helps |
