Old 05-17-2004, 12:43 PM   #1
jpeters79
jpeters79's Avatar
Tilt Steering for 67 chevy?
Just found this site today and looks like a great place to get some information. I have 1967 Chevrolet Truck was wondering what steering column I could use to convert it to tilt steering. The Steering column that is on it is currently giving me trouble when trying to put it into gear, but on th column it works fine. I want to get it fixed but would like to have tilt steering if possible. Thanks for any help that is available.
jpeters79 is offline   Reply With Quote
Old 05-17-2004, 02:00 PM   #2
Slammed67
Progress = 0%
Slammed67's Avatar
I found that the tilt steering for these trucks is pretty much useless unless you are a very short person. From centerline, there is only range of motion downward with very little or no motion upward. It would make more sense to me for it to tilt upward ....... seems backwards to me. So in my opinion, it might not be worth the extra $$$$. Anyone else have an opinoin about this?
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 05-17-2004, 02:00 PM   #3
71swb4x4
71swb4x4's Avatar
If you have an auto you can use any of the pickup tilts through 72. You can also use a van tilt, the shaft is about 2 inches longer so you have to crush the steering sleeve, its a real popular mod as it can be pretty cheap. Do a search on van tilt installation and you should find plenty of info.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 05-17-2004, 04:16 PM   #4
Putter
More Cowbell....
Putter's Avatar
Hey JPeters79,
Let me welcome you to the board. You can get almost any question answered here. If we don't know the answer, we can BS you into believing it. (J/K)
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 05-17-2004, 04:53 PM   #5
Rod
http://67-72chevytrucks.com/vboard/s...=dremel+column
There's a link to post on the van tilt mod for yah.
Your 67 if it still original may have a non-collasping lower shaft... you can grab a collapsable one from a little bit newer 68-72 truck. Sounds like your talking an automatic tranny tilt column, so this should get you going.
Welcome to the boards.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 05-17-2004, 04:57 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Welcome to the forum.
I highly recomend the tilt, even though it does tilt a little funny, I wonder how I did without now that I have it.
You can get a van tilt for next to nothing from a wrecking yard most likely. I normally get them for 25 - 35 bucks depending on what yard it is in...of course there are the yards who think they are gold too...one guy told me "I saw one on e-bay for over 100 bucks...so I'll only charge you $75"
Pffft...as if.
Anyhoo...welcome to the board. Where you at in the world?
Old 05-17-2004, 06:44 PM   #7
Pont
I need another Barley Pop
Pont's Avatar
I also would like to welcome a fellow 67 owner.
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 05-18-2004, 09:07 AM   #8
jpeters79
jpeters79's Avatar
Thanks everyone for welcoming me to the forum. I think it will be very helpful. Yes, the steering coulumn is an automatic and thanks for the input. What year van do you recommend 70's? Here is a pic of my truck in case anyone is interested.
1967 Chevy on 1976 3/4 ton Frame with bored over 427. My white beauty.
Old 05-18-2004, 09:33 AM   #9
boraxman
Keepin an eye out
boraxman's Avatar
Fine looking truck...Welcome from So.Cal.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 05-18-2004, 10:20 AM   #10
meathead95
computer illiterate
meathead95's Avatar
that is one sweet 4x4! welcome from nashville.
72 2wd blazer
72 swb 4x4
meathead95 is offline   Reply With Quote
Old 05-18-2004, 11:05 AM   #11
71swb4x4
71swb4x4's Avatar
A lot of the 70's can tilts will work. They look almost exactly like our original tilts so its pretty easy to tell when you have found one. I got one from a local yard for $40 and it had all of the levers and everything.
Shawn
Old 05-18-2004, 04:19 PM   #12
Longhorn Man
72 - 80 I think. If it is a tilt, and has the ignition in the dash, then you have a winner.
Old 05-18-2004, 05:03 PM   #13
Warbones
Navel Inspector
Warbones's Avatar
Welcome from Ks!!! Nice 67'
1948 Chevy Aerosedan GONE! I think.
1984 Cadillac Fleetwood Brougham Coupe
WANTED 1967 IMPALA
1967 CST C10 Long Bed with a 283
Warbones is offline   Reply With Quote
Old 05-18-2004, 11:24 PM   #14
super-k
GM first used the tilt(4spd&TH350/400)in trucks in`69.Thru`72 is identical.Don`t pay truck price for van tilt,beware.`72 vans until locking column(year?)works,as mentioned.Other than collapsing to fit,you need to relocate the neutral saftey switch.Vans are why black NOS steering wheels kept popping-up before the repros were available,same(almost)column/same steering wheel.Nice small-window.
72CheyenneSuperK20CustomCamper350/TH350,A/C 72SierreGrandeK2500350/TH350,A/C 72CustomDeluxeK20CustomCamperSB400/4SPD.A/C 72CustomC10SWB,TH400,project
super-k is offline   Reply With Quote
Old 05-19-2004, 05:49 PM   #15
bstack
Pics
Welcome Jpeters79. Do you have any more close up pictures you could post on your truck. I am going to build a 67 4x4 and was thinking about white as the color, and that truck looks good. Nice job!!
70-Olds 442
66-Impala 4-dr.
67-K-10
87 Chev. 1/2 Ton 4x4 Swb
bstack is offline   Reply With Quote
