![]() Join Date: Nov 2002
Ignition Trouble. Need some help.
Third part of the ignition saga with my '67.
Truck is not starting again. Turns over, has power all the way to the "BATT" spade connection on the HEI, fuel smell tells me gas is flowing, but it isn't starting. I suspect the ignition module has gone bad, and removed the distributor cap to get at the module. When I got the cap off I found a nice, clean ground wire running from an intake manifold stud at the back of the engine up to . . .nothing. The end of the wire is stripped, the wire strands are twisted together. Its is clean, and it obviously goes somewhere. Question is, where? PO did it. Its short. Only about long enough to reach the passenger side of the distributor. So, my question is, how many wires run to a '79 350 HEI? 'got the two going to the "TACH" spade and "BATT" spade on the drivers side, and I've got the plastic connector with wires that attaches under those two spades. The connector snaps into place. Any other wiring that goes to the HEI? Is it possible that the ground goes into the wires in the plastic connector on the drivers side of the HEI? Does that connector have a ground in it? Thanks for any info you might have.
"Truck" '67 small window '79 350 .030 over, LT1 "clone" |
blood type; Retumbo
I will assume that you have no spark at plugs here. remove the 'tach' wire from cap & use a regular test light to the terminal under cap. what you are looking for is a flashing light as engine is cranked over. if light is steady you have problem under cap (module or pick-up coil). if no light at all you have problem with coil on top of cap (open circuit). hope this helps.
P.S. remove coil cover & look for small metal strap going from one of the coil mounting screws to the middle of 3 wire area on bottom of cap. many times these are left out accidently by someone replacing cap.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
