Old 05-17-2004, 04:35 PM   #1
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Convert 6 lug to 8 lug?
Is this possible? I am running an 14B FF 8 lug rear already but still have the stock front axle. Trying to find out what would be the cheapest route, converting hubs if possible or finding a 3/4 ton axle.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 05-17-2004, 09:01 PM   #2
jamie72
jamie72's Avatar
if you got the correct gears,i have heard that you can get a doner 10 bolt and use the 8 lug rotors and backing plate,on your axle. don`t hold me to that,i personaly haven`t done it.
but if you need gears too,then id just swap out the whole axle..
good luck jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-18-2004, 01:00 PM   #3
fanman
I think there is an article about this over on http://www.coloradok5.com It should be in the Tech pages.
Edit: Here's the article http://www.coloradok5.com/8lugconversion.shtml
"When I start my car in the morning I want the neighbors to think the world is comming to an end." Homer Simpson
I'm not stuck, I've still got some gas left"
fanman is offline   Reply With Quote
Old 05-18-2004, 02:31 PM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Great write up. Thanks!!!
Old 05-20-2004, 01:02 AM   #5
kwmech
Depends on the year of the front axle you have. Most of the time what is required is the hub/rotor assy and the backing plates--you can use the same calipers. The later model 8 lug hubs use the internal locking hubs and the large inner wheel bearing [104949] which requires the later model spindle.
