Old 05-17-2004, 11:48 PM   #1
aggiedave98
how to install rear leaf springs
I'm putting in my 2" lifted rear leaf springs this weekend.
Any tips?
Where should I jack up the suburban in the rear? Any other helpful tips would be welcome.
aggiedave98 is offline   Reply With Quote
Old 05-17-2004, 11:58 PM   #2
KutThroatKustoms
drag body or die
jack it up on the frame, stick jack stands under the frame, then use the jack to stick pressure on the rear axle.. unbolt the u bolts, then you can lower the rear down a little and unbolt the spring.
-Bobby-
KutThroatKustoms is offline   Reply With Quote
Old 05-18-2004, 03:07 AM   #3
Fat Tom
Just unbolt the U bolts, then jack the frame up, and then unbolt the shackle from the spring, or just torch the bolt off, then unbolt from the spring hanger. Install the new spring in the reverse order. Do one side at a time. You might have to unbolt your shocks too.
69 GMC 2wd 350cid
82 Toyota 4wd, 3.8L V6, 6" lift, 35's, locked and loaded
76 Datsun F10 1.4L ***FOR SALE***
04 Honda Shadow 750
Fat Tom is offline   Reply With Quote
Old 05-18-2004, 11:05 PM   #4
Rick James
well said Bobby/KTK. i used the same methon on my '73 GMC's rear 2" lift. problem is, i'm not sure how to tackle the front end...
it's a 2wd pickup so i bought a spring kit for the front but it came with no real instructions... any advice?
thanks,
RJ.
Rick James is offline   Reply With Quote
Old 05-19-2004, 08:46 AM   #5
eaglelox
Member Dude
eaglelox's Avatar
springs on the front went faster for me. one side at a time. attach front first.
when you do the rear if both sides are disconected, my differential wanted to flex a little at the Ujoint.
just seen you were talking 2 wheel.oops.
Steve
1978 K20 Burb, 4" lift, 33's, 350
Eaglelox@Hotmail.com
eaglelox is offline   Reply With Quote
