My 73 K5 window sticker says it has "Optional Axle Ratio" with an RPO of "1ZN8" (or "ZN8"). I know there are several websites that have pretty comprehensive RPO code listings, but I have never found anything on this RPO--can anyone help me figure out what axle ratio I have (without doing the tire size/rpm/mph math) ??? Thanks !
just jack up on wheel and spin it 2 revolutions and count the driveshaft turns. that's without posi
if you have posi, jack up both wheels and spin one revolution. you'll know that you have posi if you can't spin the one wheel when you have it jacked. |
You get what you pay for
![]() Join Date: Dec 1999
On the axle tube, passenger side, front, out about 6" from the center section, there should be a die punched code. It's real hard to find sometimes. The letters are small, about 1/8" in size. You will need to clean it off real good to find them. When you find them, post back here and I'll check the code for you.
Mike 1985 Chevy C-10 |
Odd...it doesn't say what the ratio is after it? I thought if it had anything other then the stock gear it listed the RPO AND the ratio. My 79 Showed it had the 3.73.
If it's a factoy v8 the 3.73 is usualy the otion gear and if it's a I6 4.10 is the option gear. Your truck being a 73 HAD a tag on one of the cover bolt on that D44 in the front. See if it's still there. I'm coming up blank on the code. Most Z RPO's have to do with appearance packages and Paint info like two tone.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
#5 | |
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 Last edited by 1969 GMC; 05-18-2004 at 02:48 PM. Reason: forgot image, im a dumbass! |
