05-18-2004, 12:42 PM | #1 |
Heads for my SBC
I was wondering what would be the best heads for my 327 sb in my truck. I am looking to put some heads and a cam in. I was hoping to get the heads and the cam for under $600 total. My older bros were gonna help me put it all in. Iwas just wondering if you guys knew of any good heads that would give me about 50hp bolt on for a reasonable price. thanks!
-Keegan- '72 Jimmy 4x4 - 5.3/4L65E/NP205 swap http://67-72chevytrucks.com/vboard/s...d.php?t=663780 |
05-18-2004, 03:37 PM | #2 |
Cantankerous Geezer
For a stock engine Vortecs are the best bang for your buck. However, they take a different intake bolt pattern, which will put you over the $600 price limit.
Fred There is no such thing as too much cam...just not enough engine. |
05-18-2004, 07:26 PM | #3 |
You can get rebuilt big valve heads for under $500 and will leave you enough for a Summit cam at $90. Get the older 64 cc heads so you keep your compression up. I dont know what style accessory brackets you have, but you will need to make sure the heads have the same holes that your accesories use. You either have them or don't, easy to see. If you can find the old LT1 heads they have screw in studs and have the 2.02 intake valves.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. |
05-18-2004, 08:47 PM | #4 |
aren't lt1 heads reverse flow so you can't use them on a standard small block chevy
05-18-2004, 09:59 PM | #5 |
2.02/1.60 camel backs plus they look cool on a 327 for someone who knows what they are looking at
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
05-18-2004, 10:04 PM | #6 | |
05-18-2004, 10:05 PM | #7 |
Somewhere on this board are some pics of cyl heads I have for sale, I searched but could not find at the moment. They are off a 70 350 camaro/corvette. Camel bump--194/150s hard valve seats, screw studs, guide plates, pc seals, surfaced, accessory holes. Completely rebuilt. $500.00 firm. Have had quite a few inquiries but no cash as of yet.
05-19-2004, 08:19 AM | #8 |
Arent the old LT1 heads the ones used in the early 70's? and weren't they prone to cracking and the performance really was terrible with this?
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
05-19-2004, 11:06 AM | #9 |
How about some heads off a 350 tpi camaro? For that cheap that would probably be the best choice.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
05-19-2004, 11:17 AM | #10 |
Get some good used vortec heads, and a new cam and intake. You should be able to get some good used heads for 300-350. intake-100 or so, cam-100 for a total of total 500-550. you can find the heads on core motors that were pulled because of a rod knock or somthing. they will be cheaper that way and the knock dos'nt affect the heads.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
05-19-2004, 11:21 AM | #11 |
The old LT1 heads are the best stock heads as far as performance and durability, they were used on the Vettes and 70-72 Z28, and an earlier version was used on the 67-69 Z28 but I think they had press in studs. The newer heads have 76 cc chambers and will have low compression, like 8 to 1 at the best with dished pistons used in the low comp engines. Anything after 1977 used the crappy lightweight heads, not much good for long life and cracking between the valves. The TPI heads are ok but not great for performance like the older LT1's are.
The vortec heads are an excellent stock head but you cant go over .480 lift on the cam with the stock springs. I have them on my 83 El Camino and they work great. I would spend the extra $200 and get the whole kit new though, its around $700 but you get the assembled heads, head bolts, gaskets, choice of performer or performer RPM intakes, rocker arms, pushrods and sopme other things. If you buy used heads you may have to rebuild them which will be way over new by the time you factor in labor and parts on top of the initial purchase.
72 Chevy C20, SOLD (Dang it.) 09 Challanger RT six speed in all black. 74 Datsun 710 wagon, all 1.8 liters of screaming Datsun power. 73 C10 long bed, 350/350 combo, nice shape. Last edited by 72C203503ONTHETREE; 05-19-2004 at 11:24 AM. |
