05-18-2004, 01:06 PM | #1 |
BBC headers for manual trans ???
I have a '69 Chevy with a BBC 396/TH-400 combo. I am changing to a TKO-500 or TKO-600 in the near future and will use the factory linkage. Is anyone running a factory 396/402 with a manual trans and factory linkage with a set of headers? Also, I have airbags so ground clearance is an issue.
1967 Chevy Short/Fleet 1969 Chevy Short/Step 2004.5 Dodge 2500 4x4 Cummins 6spd |
05-18-2004, 05:00 PM | #2 |
I use to have a 4-speed/396/headers in my 4x4. I made a "U" shaped peice of 1/4 x 1 1/4 metal strap and welded it to the z-bar frame mount. shortened the z-bar to fit inside that. Dont know if anyone makes headers for a bbc/4speed combo that fits our trucks. My heddmans were supposed to fit manuels , but didnt.
67 3/4 4x4 402,a/t,flat bed 98 GMC Sierra swb daily driver 87 burb parting out. 68 1/2 chevy, 350/350, 71 gmc frame, kid's beater 69 1ton 396-4sp, dump 69 swb stepside 396/400th current frameup 67 swb 454/400th rebuilding now, oldest boy just rolled it 99,HD, Road King Classic Colwich Ks |
05-18-2004, 06:02 PM | #3 |
To my knowledge, no such animal exists.
How about using some of the chevelle 3/4 length headers (which are for auto's only) & modify the drivers side to co-exist w/the z-bar & linkage? That would be cheaper than a set built from scratch. Or McCleod (sp?) makes a modular bellhousing that can adapt a hydraulic clutch set-up (& the T-56) possibly allowing the use of the automatic style headers w/o modifying.
05-18-2004, 07:15 PM | #4 |
I am trying to stay away from a hydraulic clutch setup and the T-56. I have all the factory clutch linkage and am currently working with SpeedDirect on a rod end bearing linkage for big block applications. I know a few customers who are running Sanderson BB3 headers for automatic applications but they will not fit the manual linkage.
05-18-2004, 09:39 PM | #5 |
my hooker super comps fit with a big block and a muncie 4 speed.
68 chevy 406 small block, budget drag racer, new best e.t 11.91 @112 67 nova numbers matching 327 4 speed 13.6 @ 102mph 70 longhorn c-30 402/4 speed 70 c-10 swb 402, muncie 4 speed 94 s-10 350/th350 3:73 posi 71 c-20 402/th400 towrig for racetruck. 72 4wd lifted on 35's 72 350/3 speed winter beater |
05-18-2004, 09:56 PM | #6 |
I need another Barley Pop
My Hooker Comps also fit in my truck without any clearance issues on the drivers side. I did have to do some frame and header mods for the passenger side.
67 Short Fleet 4x4 04 Honda CRF450R 89 Toyota 4-Runner 34 Ford 2 door sedan - Long term project ---------------------------------------------- There is a very fine line between "hobby" and "mental illness" |
05-18-2004, 11:35 PM | #7 |
My Flowtech ceramic coated headers fit my big block truck with muncie 4 speed as well........
Joe |
05-19-2004, 08:05 AM | #8 |
Try the DYN86022 Dynamax ceramics, my customers seem very happy with the fit on manual trans trucks.
Rest in Peace Ed. Thanks for all the good times. |
05-19-2004, 11:29 AM | #9 |
John,...how did you get an avitar after only 3 posts???
https://www.ebay.com/itm/295742064443 |
05-19-2004, 11:33 AM | #10 |
I don't know. I tried it and it worked. It must be my lucky day !!!
