05-18-2004, 02:58 PM | #1 |
Garage Queen Material
wish me luck thursday
taking the truck out to the track thursday night. i wonder what it will run. low 15? high 14?
maybe |
05-18-2004, 05:21 PM | #2 | |
05-18-2004, 06:16 PM | #3 |
Eric, good luck. have fun and dont break anything!
Tim, try to argue with someone at the try about why you lost the race even though your trap speed was higher. |
05-18-2004, 06:32 PM | #4 | |
i dont think i'll break anything. i've already pushed it as much as possible. just not its safer cause its on the track |
05-18-2004, 06:32 PM | #5 |
oh yeah, i guess i should mention that this is the first time i've ever raced at a track, or well... raced anytime
05-18-2004, 08:48 PM | #6 |
Just don't wreck it.
Gary -1986 SWB: lowered 4/6, SOLD!!! -Best 1/4 mile: 14.51 @ 91.01 MPH -2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!! -2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels |
05-18-2004, 09:58 PM | #7 |
It followed me home?
man i would have guessed LOW 14's? I guess that shows what I know. About how much hp, torque do you think you have?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
05-19-2004, 12:13 AM | #8 |
when it gets tuned right, holley says that the systemax kit will make 425hp.
i'm guessing mine should be right around there, give or take 10/15hp? i'm betting that when it gets tuned right, and i get good tires and gears, it should run low 13's |
05-19-2004, 02:08 AM | #9 |
BAD BOW-Silverado XST
You better get into the 15 or else I'm right behind you.
Launch on the last yellow light!! Leaving RMP should be about 1000 RPMs or just about to break loose on the tires. What the rearend ratio? Do a manual shift 1-2 or just take on in 2nd. Just be at max RPMs at the 1/8 or 1/4. |
05-19-2004, 02:19 AM | #10 |
2.73 gears
05-19-2004, 03:18 AM | #11 | |
\/ My Loves \/
78' Silverado - Blue - (In a Coma) 04' Silverado -Red- 383 Stroker in progress for the 78'!!! |
05-19-2004, 03:27 AM | #12 |
425crank HP.
so maybe around 350-370rwhp?? i need to get my 3.73's, but i wanted to do my gears and posi at the same time and the eaton posi is expensiveness. oklahoma city, ok |
05-19-2004, 10:47 AM | #13 |
like G said, launch on the last yellow light. If you see green you are too late... and if you see red... well you were too early. good luck, i wish i could come watch ya, but i have to work. Maybe if it was saturday night i could come.
05-19-2004, 10:50 AM | #14 |
Active Member
You should be good for 14's.....my Blazer ran a 14.6 @ 93 mph
it's a 355 with vortec heads, smaller cam than yours and a 600 holley. Plus I've got some weight on ya also. Only thing really helping me are the 4.10's anyways...good luck and have fun, that first run down the track is a BLAST!! |
05-19-2004, 10:52 AM | #15 |
oc, where you going? Thunder Valley?? I'm off Thursday and thinking about coming down to watch. Just to keep you honest... :P
Robert Current: 1986 SWB Silverado 4.3 / TH400 Past: 1985 SWB Silverado 305 / TH350 - sold 1995 1987 1/2 ton Silverado - FI 350 / 700R4 sold 2007 |
05-19-2004, 11:22 AM | #16 |
yeah, thunder valley.
i'll have the girlfriend there taking videos too |
05-19-2004, 02:13 PM | #17 | |
\/ My Loves \/
05-19-2004, 02:37 PM | #18 |
I recently took my truck to the strip with the new ZZ430 and with 3.73 gears and too much wheelspin ran a 14.2 @ 100 MPH. Problem is mostly the gearing in that I went thru the traps at around only 4,500 RPM's.
Engine not broken in yet, still fine tuning, and will go back when 4.10 gears are in. Truck weighs 4,150 pounds. So, these trucks are heavy and need at least 4.10's to do anything and that is still not enough.
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL. |
05-19-2004, 02:42 PM | #19 |
yeller
Your gears are going to kill you off the line...I would leave at about 1200-1300 RPM. Also, make sure your seat belts are installed and work, battery is down tight (if it is relocated, make sure you have a visible off/on switch out back somewhere), you need to have an overflow for the radiator, make sure you have all lug nuts on, and make sure your truck doesn't leak fluids. You will also need a helmet in case you don't have one.
With all that being said, since it is your first time and because of your gears...I would bet mid to high 14's.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
05-19-2004, 02:50 PM | #20 |
it says on the rules at there website that the vehicle "must have factory tint on windows"
is that an nhra rule or something they really wont care about? |
05-19-2004, 03:32 PM | #21 | |
\/ My Loves \/
05-19-2004, 03:43 PM | #22 |
thats what i figured. i dont know why it says that on there website. but i also dont have to wear a helmet or have a driveshaft safety loop if i run anything above a 13.99
05-19-2004, 03:45 PM | #23 |
13.99 or quicker must have Snell 90, 95, K98, 2000, SFI 31.1A ,31.2A, 41.1A, OR 41.2A helmet
If car has T-tops or is a convertible, the driver must have Snell 90, 95, K98, 2000, SFI 31.1A ,31.2A, 41.1A, OR 41.2A helmet Neck collar mandatory in all cars running 9.99 or quicker or exceeding 135 M.P.H. Convertibles must have roll bar if running 13.99 or quicker Automatic transmission lines must be high pressure type Pressurized containers (i.e. air bottles) must be DOT approved Hood scoops may not extend more than 11 inches above original hood surface Carburetor return springs If linkage altered, must have toe loop on pedal All holes in floor, firewall, and rear must be plugged Fuel block or regulator must be 6 inches from firewall and rear must be plugged No more than 12 inches of rubber hose in fuel system from tank to carburetor No fuel lines in drivers compartment Retention strap mandatory with traction bars Drive shaft loop required 13.99 or quicker Roll bar mandatory in all cars running 11.00-11.99 Roll cage mandatory in all vehicles running 10.99 or quicker or any car exceeding 135 mph. Three inch driver restraint system (seat harness) SFI Spec 16.1 mandatory in any car 11. 99 or quicker and convertibles 13.99 and quicker. Master cut-off mandatory for vehicles 9.99 and quicker or 135 m.p.h. or if battery is relocated. Jacket required at 10.00 to 11.99 meeting SFI Spec 3.2A/I Jacket and pants (meeting SFI Spec 3.2 A/5) and gloves (meeting SFI Spec 3.3/1) required at 9.99 to 7.50 or any vehicle exceeding 135 m.p.h. Only factory tint on windows Must have metal valve stems 11.99 or quicker 9.99 cars must be chassis certified and have NHRA license |
05-19-2004, 04:02 PM | #24 | |
\/ My Loves \/
DAM!!! I though our track was strict lol. Thats tons of rules. Down here at Penwell our 1/4 mile traucki. 11.00 or less..Helmet and Roll cage, T-Tops must be clamped down at all times..if not u wear a helmet. Driveshaft loops arent required. Pretty much you go there...line up and race. If ur 12 or less and/or have T-Top's....u dont need anything but youself in the drivers seat
05-19-2004, 04:17 PM | #25 |
Eric, I really think you are blowing this way out of proportion. Those rules would apply to a NHRA sanctioned event. The most you should need is working head/tail lights, brake lights and a seat belt. So just go and have fun and blow a few mustanks away. PS: Be sure she gets some good video.
