05-18-2004, 03:39 PM | #1 |
axle question-1/2 ton 2wd
I have been told that the '70 rear axles will interchange with the '71-'72 rear ends. They are supposedly the same length and will just slip right in. According to the source, I have been told the '67-'69 axles are longer and will not work but that the '70-'72's are all the same length. Is this true?
05-18-2004, 05:27 PM | #2 |
I have been told that the 67-69 are different as well. There is a company that sells the 5 lug conversion axles for the 67-69 diffs though.
I know what your thinking.......I have ESPN. Sometimes it's easier to do things the hard way. Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! |
05-18-2004, 05:48 PM | #3 |
Designated A-hole!
They changed the length in the middle of the 70 model year, so you would have to measure a 70 to see which it is.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
05-18-2004, 06:05 PM | #4 |
I think 67-70 are 3/4 of an inch shorter then some of the 70 and 71-72. I have 72 axles in my 69 rearend and had to space the backing plate so the brake would go in the drum all the way.
05-18-2004, 07:44 PM | #5 |
Yeah I had to do the same thing I had 3/4" spacer on each side allso used the newer drums.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
05-18-2004, 09:50 PM | #6 |
blood type; Retumbo
FYI the 72 type axles are the same as '80 for the standard 10 bolt. 12 bolt (DANA 44) are same length but different spline count & diameter.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
05-18-2004, 11:15 PM | #7 |
Welcome to the board. Just a helpful hint, go into user CP and update your profile. Include at least the state you live in. Also, in the signature spot jot down what year truck you have. It makes it real easy for people to then tell you that they have those parts, or would be willing to come and help you, etc.
Andy,Phx AZ '67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...) "23 C-Cab-sold '48 Ford 8N tractor(still working) '67 Scout(Now on the road) '70 MG B.-sold |
05-19-2004, 12:54 AM | #8 |
Hey Duece, who sells that conversion kit if this little plan of mine doesn't work? And approx how much is it?
-Greg My Chevy trucks, past and present: 1962 C10 SB Fleetside 1964 C10 LB Fleetside BBW 1966 C10 SB Fleetside 1966 C10 SB Fleetside BBW 1968 C10 SB Fleetside 1971 C10 LB Fleetside 1971 C10 SB Fleetside 1972 C10 SB Fleetside Cheyenne 1972 C10 SB Fleetside Cheyenne Super 1972 C10 LB Fleetside Cheyenne Super 1974 C20 Cheyenne 1979 K5 Blazer Cheyenne 1982 K10 SB Fleetside Custom Deluxe 1982 K10 SB Fleetside Scottsdale 1986 C10 SB Fleetside Silverado 2008 Silverado 1500 4x4 |
05-19-2004, 09:22 AM | #9 |
Gotta Startem Early
Early Classic has the 5 lug conversion axles
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
05-19-2004, 09:31 AM | #10 |
Keepin an eye out
They can go either way for '70. I was lucky had the wider rear.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
05-19-2004, 11:37 AM | #11 |
I used a pair from a 77 12 bolt in my 70. Fit fine.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
05-19-2004, 01:12 PM | #12 | |
Here ya go.
05-19-2004, 03:49 PM | #13 |
Hey Thanks, if my '72 axles don't slip into the '70 rearend, I will buy the kit. That's pretty slick!
