does any one have pics of4 link with airbags
hi everyone looking for pics of 4 link set up with air bags thanks everyone for any help
(If all else fails get a bigger hammer) |
Here is the set-up that Lost Wages has on his truck. I am thinking of doing close to the same.
1972 Blazer body...need to get a thread started for the rest of the story |
Is a 4 link necessary with the trailing arm and coil rear? Just curious.
Shawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
Jorgensenc,
It all depends on how low you are going. Looking at many of the lowered trucks I have seen, you eventually get interference with the panhard bar or the trailing arms and the bottom of the frame. I also think it gives a much cleaner look to the rear suspension.
More Cowbell....
I was actually wondering the same thing as Jorgensenc. I want to keep my trailing arms, replace the springs with bags, and replace the tracbar with something else....but what? I understand that the tracbar will work for a "set height" like using lowered springs, so the truck runs at nearly the same height everyday, but I want adjustment ability. Can some setup like in photo 1 be used where a pair of bars connect the chunk to the frame while using my stock trailing arms? I know there is a bag-guy out there that has an idea or has done it himself. What can replace the tracbar?
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
Flamin' Bass
The kit supplied by Airlift has a variable length trackbar and relocates the attachment point from the top of the diff to a bracket at the bottom of the right side trailing arm. This reduces most of the problems with keeping a trackbar. I have a small (4" ) notch and bags where the springs were. I have the trackbar adjusted for the 'normal' ride height to keep the alignment correct (diff centered in the frame), but when I dump the bags the frame does shift off center a little, maybe 1/2". But when dropped, I'm only cruising the parking lot, not the highway, so the offset doesn't matter that much.
Rick Olson /nosto/ Galloway, NJ Pics : http://community.webshots.com/user/nosto53 1972 Triumph TR6 - full resto, now with a Toyota 5-speed 1975 F**D F-100 - rusty, but reliable 1982 HD XLH-1000 1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!! |
ECE also offers an adjustable track bar if you go with another company for the airbags, like AirRide Technologies.
here is another way of doing it.
![]() ![]() Last edited by Glen; 05-19-2004 at 11:11 PM. |
