Registered Smarta$$
i got some used turn signal lens with the harnnes. my question is that when hooked it up looked great, but when i check to see if it all work the drive side worked great. the passnager side is dim and the driver side binks dim. any info would help thanks
Turn signals
If your wiring/connections are all good, I would probably check for good grounds. Make sure anything that needs to be grounded is grounded on a spot that's clean, not corroded/painted. Hope this helps -Noah
Registered Smarta$$
i'm using chevy set up on my gmc. and the driver side has three wires and the other side has two would that make a difference? any info would help
I just bought a harness from LMC and its like what you
described. That third wire on mine is a pigtail park light wire for license plate light, has a small male plug on end of it. Shouldn't have anything to do with your problem. I'm thinkin like noah, bad ground. ![]()
64 Chevy pickup tilt,pb, ps discs up front 350/TH350, 72 rearend auto meter gauges 93 GMC extended cab trailmaster conversion |
Registered Smarta$$
i fix my problem all i did was take a little file and filed down the progs in the connector and that was it.
