Old 05-19-2004, 09:16 AM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Rear sway bar
Are there any problems with running a bigger diameter sway bar in the rear then in the front on a coil spring truck. I have the stock bar in front.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 05-19-2004, 03:26 PM   #2
LONGHAIR
You need to have a bigger bar in the front to have any swaybar in the rear at all! You will get and unsafe under-steer (push) if you don't keep them matched. This is even more pronounced in the rain.
On any vehicle where there is a rear-bar option the front bar is changed too.
LONGHAIR is offline   Reply With Quote
Old 05-19-2004, 04:32 PM   #3
ocbaud
Garage Queen Material
i have the stock 1/2 front bar on my truck and the same size aftermarket hellwig bar in the back. the only thing it did was improve performance
although i know i should get a bigger bar in teh front to take the most advantage of it all, i just havent had time to go pick one up yet.
ocbaud is offline   Reply With Quote
