05-19-2004, 07:51 PM | #1 |
Tricks to removing windshield wiper arms?
Im sure they make a special tool, but does anyone know any tricks to get them off with out the tool? thanks
Just sitting here contemplating contemplation. |
05-19-2004, 08:07 PM | #2 |
i love summertime
yeah they make a tool, what has worked for me is using a small flat head screw driver, you need to push that little tab back and pull at the same time, just be careful!!! i put the wipers on my 67 last week and i got one on crooked and yanked it off and the f'er went flying and scuffed my brand new paint job on the hood!
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
05-19-2004, 08:08 PM | #3 |
Sure, POC, use a small prybar (the kind carpenters use to remove interior wood trim). Put a piece of rag on the cowl so you don't scratch it. Gently pry up and vola.
Harry
6T727T2 |
05-19-2004, 08:23 PM | #4 |
you can use a claw hammer as well. Gently pry up at it will pop off. Just protect that paint!!!
1954 GMC 150 (for sale) 1970 GMC 1500 2004 Road King |
05-19-2004, 08:53 PM | #5 |
Almost done!
Use a pair of channel lock, slip joint pliers. Open the pliers up to the last slip joint, (mainly to get the lower jaw out of your way.) Catch the tip under the edge of the wiper arm and push down on the handle. The size and angle are perfect for removing the most difficult wiper arm. Put a strip of duck tape on the edge to protect your paint.
The 1970 SWB Project Removed 6cyl manual trans, manual everything V8-350 Auto/PS/PDB Blazer Fuel Tank Behind the Marker Light Fuel Fill |
05-19-2004, 09:05 PM | #6 |
blood type; Retumbo
the tool designed is avail. from Snap-on for about $6 you could make one with a 6" piece of 1" x1/16 flat stock. need to bend very edge about 3/16 & again at about 1" beyond that. it will look like a squared off 'U'. then at about the 3" line do about a 15 deg. bend away from wiper arm. just slip the tip of 'U' under end of arm & gently pry back then lift arm from shaft. does not hurt finish on truck. may want duct tape on arm if they are painted though.
Todd
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
05-19-2004, 10:07 PM | #7 |
Its Magically Delicious
i use angled pair of needle nose pliers and channel locks wrapped in a rag , the 1st time i ever did it .... i can take them off with my bare hands now
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
05-19-2004, 10:41 PM | #8 |
Got them off, thanks!
