Minimum amount of space between axle and frame??
On my 75 C10, how much space do I need between the axle tube, and the framerail, before I need to add a C-Notch? Would 2" Be too little space and I would run into bottoming-out problems?
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
If you don't mind it beating the heck out of the frame 2" isn't bad..
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
I went 3" on mine and the guys I purchased my 4link from said 3" as well. If you have a heavy setup of a suspension you should be able to get away with 2" but always keep in mind if you load it up to check how much room is here so not to damage anything.
1967 C10 - SWBSS Pro Street 427sbc, 700R4 & 4.10 Gears 1948 Chevy FleetMaster Coupe, LS1, (almost done) 1950 Chevy StyleLine Coupe 250/6 3x2 Dueces 2009 Toyota Tundra 1996 Harley RoadKing "I maybe getting old, but I can still burn rubber with the best of them" |
Under construction!
Don't be a wimp, install a notch.
2001 Silverado bagged on 22's. *Sold* |
so is the essence of the opinion of this mod is ... if you flip your rr axle.... "C" notch the frame?? I dedeuce correctly???
You get what you pay for
Yes, you deduce correctly. I used a shackle in the lower hole and a 5" flip kit, which gave me a 6" drop. I had 2-3/4" left in clearance between the frame and axle tube. I drove it this way for a few weeks. After one too many teeth rattling, bone jarring bumps, I installed a notch.
Tim, install a notch in that thing and be done with it.
Mike 1985 Chevy C-10 |
Well, right now, I have a FULL 5" of distance between the top of the axle, and the frame, so I think if I do the WC Shackles, and put them in the bottom hole and get the 1" of drop or so, I'll be ok. I probably will end up notching it though...
Fabricate till you "puke"
I have 2 1/2" tween the axle & rails on my longhorn. it hasnt caused any problems, but those old leaf springs were pretty stiff. i do agree with the rest of the guys tho, you need a minimum of about 3" for a civilized ride. crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
is the 2" measurement with truck on load to ground? from bump stop to rail?
#10 | |
