Old 05-19-2004, 10:15 PM   #1
ljbear
ljbear's Avatar
1980 Differential Questions
I found a 1980 Chevy 3/4 4x4 with a V8, SM465 and NP 205 and need to know if there was a standard or normal ratio for this set up. The glove box is gone and the owner doesn't know. Looks to have a 14bolt rear, not sure on the front. So, anyone able to give some input what I'm likely looking at? Thanks
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
"Don't confuse enthusiasm with capability"
ljbear is offline   Reply With Quote
Old 05-19-2004, 10:36 PM   #2
Devil'S Ride
Since its a 1980 an 3/4 ton, I know you have a Corporte 14 out back, an more than likely a Dana 44 up front. Also, more than likely, your gear ratio is a 410 out back an 410 or 411 up front. You got a killer drive train setup. Have fun with the truck!
The Devil
1983 ONE TON 454/400/208 11" of lift on 44's
Devil'S Ride is offline   Reply With Quote
Old 05-19-2004, 10:47 PM   #3
drink2mny
drink2mny's Avatar
I 2nd that
Support The Board
drink2mny is offline   Reply With Quote
Old 05-20-2004, 12:23 AM   #4
1969 GMC
1969 GMC's Avatar
I would lean towards a 10 bolt in the front, but they are equal to d44. And you have a 14bff out back unless something else was swapped.
one goodthing about ALL 1980 GM 4x4 trucks: they all had NP205's, regardless of what transmission or what model
one bad thing: all of the NP205's are the slip yoke version, which has a large aluminum tail cone on the rear output. however, this can be fixed with parts from another 205, and there might even be a SYE kit available.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-20-2004, 01:21 AM   #5
ljbear
ljbear's Avatar
I went back and took a closer look this evening. 10 Bolt Front, Corp 14 Bolt in the rear. He wants to keep the motor and a few small parts, so I got the rest of the truck for a reasonable price. I'll be putting the axles in my 71 SWB after getting them overhauled and prettied up some. I just had to have 3/4 ton axles. I'd already built my 1/2 ton axles and had them under the truck, guess I'll start all over and put that stuff under the Blazer. Thanks for the help.
Larry
72 Chevy SWB 4x4
71 Chevy SWB 4x4
My Work Truck
