Old 05-19-2004, 10:28 PM   #1
mkmiller1
mkmiller1's Avatar
14B FF questions
I'm looking for a 14 B FF for my '72. Is there any that will bolt in without having to move the spring perches? I've got a one in a '79 4x4 but the perches are wider on that one by a couple of inches. Give me some info if you can.
Thanks,
Matthew
GOD is good...All the time!
'71 swb custom10 barn find-68K original miles
72 K5 CST rust bucket, but runs and drives 84K miles
mkmiller1 is offline   Reply With Quote
Old 05-19-2004, 10:48 PM   #2
drink2mny
drink2mny's Avatar
I haven't heard of one.. I believe the 14bFF started in '73-'74
Support The Board
drink2mny is offline   Reply With Quote
Old 05-19-2004, 11:22 PM   #3
teeitup
Just like to part out trucks!!
teeitup's Avatar
Matthew, I got some 4.10's, 4.56's, and 3.73's 14 bolts up here. Do some trading on that swb 4x4 you have.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 05-20-2004, 01:00 AM   #4
ryanroo
ryanroo's Avatar
i have a 14 bolt ff in my 72 and it went in just fine, if you find one from the 1 ton trucks 73-87 they should fit with no perch mods.
Ryan
72 K20 12v build
72 K20 "parts truck"
ryanroo is offline   Reply With Quote
Old 05-20-2004, 11:36 AM   #5
mkmiller1
mkmiller1's Avatar
ryanroo-thanks for the info
teeitup-randy, let me know if you have any with 40" C to C spring perches. I'm needing this in 4.56 from a single rear wheel(SRW) truck to match the D60 going up front . Also, I'd prefer an open carrier so I can put a detroit in. Now am I picky or what!!!!
If i can't find a SRW with correct perches, would it be easier to convert a dual rear to single or just move the perches?
Matthew
Old 05-20-2004, 11:45 AM   #6
1969 GMC
1969 GMC's Avatar
if you find an axle from a dually truck, there's a good chance it is a dana 70. about the same as a 14 bolt, except 10 bolts on the diff cover vs 14.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 05-20-2004, 04:00 PM   #7
Beast388
Suburbans RULE!
Beast388's Avatar
The 14BFF that came in the 1-tons have a C to C distance of 40.5" Our old trucks have a C to C distance of 40". The 1-ton 14BBF will bolt in with a bit of prying on the springs. You will still need to move the shock mounts though.
I used a 3/4 ton 14BFF and just moved the perches and shock mounts.
--Ben
71 GMC Suburban 4X4
The "Beast"
388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's.
Beast388 is offline   Reply With Quote
Old 05-20-2004, 04:38 PM   #8
teeitup
teeitup's Avatar
I'll try to look tonight Matthew.
1980 chevy swb 4x4
Old 05-20-2004, 07:24 PM   #9
Truckstuff
Truckstuff's Avatar
73-80 2wd 3/4Ton Crew cabs also have the narrow spring perches.
Real Trucks are Built not Bought
Building: 1981 GM SB LowRider
1985 GM K3500 3+3
1981 GM K2500 SSB
1980 GM K2500 X-BC Hydro
1979 GM K3500 3+3
1976 GM K5 Blazer
1970 Custom 10
http://bc4x4.com/
Truckstuff is offline   Reply With Quote
Old 05-20-2004, 09:10 PM   #10
1FaastC10
1FaastC10's Avatar
since a C and C was mentioned, my C and C dually K30 is most defiitely a 14FF. D70s were mostly full width duallys, mine looks as if it would almost fit both tires behind stock fenders.
1FaastC10 is offline   Reply With Quote
Old 05-21-2004, 05:10 PM   #11
poff
FYI: If you end up with a '73 axle and you have a problem getting wheel cylinders, get '74 rear wheel cylinders. The '73 cylinders were only used for one year. The '74s take different lines but they are easier to find. Everything else should be the same. Also if you want to put a Detroit locker in it, make sure you get an open carrier not a posi.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 05-23-2004, 03:01 PM   #12
mkmiller1
mkmiller1's Avatar
Thanks for the info folks.
