Looking for a tilt column in good condition. Not sure what all years will fit into these trucks, so I am starting my search here. If someone can tell me the years that will interchange, that would be awesome!!
Also need a brake booster for a '68 cab, running on a '72 frame (front disc's). Oh, and I am running a 350, power steering, and no a/c....if any of that makes a difference on the parts. Interior: If anyone has a full set of door panels/arm rest, visors, seat belts that are either black or burgundy in color for sale, I would be interested. Or even the seat belts and visors....I can redo my own door panels if need be. ![]() ![]()
"Trucks with Class"
![]() Join Date: Jul 2000
71-2 PU tilts are the best fit...BU lights & neut switch will plug right in. I have a nice used one for sale or new built one, also. Van tilts can be made to work, but you won't have the BU & neut function unless you cut it open and do some mods.
1/2T brake boosters from 67-72 should all work, but you should use the MC & prop valve from DB truck. If you get over to this side of the mountain, stop in. I will have everything you need. |
