Need some help with the A.C. Vents Please.
I'm installing a vintage air setup and will be putting the stock Vents on the sides (not the ones that came with the V.A. setup). Does anyone out there have access to a factory A.C. dash and can either take some measurements for me or draw a template on a piece of paper and fax it to me? I don't want to screw this up when I cut the dash. Thanks in advance!!
Shawn A.C. Will Rock!!! ![]()
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
its all about the +6 inches
My A/C cab is about 40 miles away...so i can't help.
I wonder if you'll still be considered a dash hacker? Same thing...cutting up a dash for a more enjouable drive... Cut that sucker up and don't look back. ![]() |
I'm trying do be reasonable with the hacking you know
![]() Thanks for the thought though.
What measurements do you want, ac cab in the garage and I will do it now.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
The side vents from whatever spots ware good measurement points, Maybe from the bottom up, from the side over to the edge of the hole, and maybe the diameter of the hole. Does the hole extend into the curved part of the dash? Thanks for the help whenever you can get to it.
Shawn
I have an AC dash at home. If you still don't have what you need when I get home tonight I will take pics and measurements.
Shanw
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
Thanks I appreciate it!!
Gotta Startem Early
Isnt there a template in the kit from Vintage, if not I have the manual in pdf form I can send you the template.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished |
The template in the kit is for the ball vents that they use. I want to use the stock factory vents and they have a different location for the hole. If you have a template for the factory vents that would be awesome though!
Shawn
member #16
![]() Join Date: Dec 1999
Heres a template if you can get it to the right size. It is on a 8 1/2x11 in. sheet. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Wow!! Thanks john I will see if I can get that to print up. By the way, the gauge metal piece you sent me for the tachometer works great!!! I'll post a pic sometime soon!!
Shawn
Here are some pics Shawn.
#13 |
Thanks for the Pics!! Between those and the dimensions and templat above I should be able to work something out!! Thanks again guys!
Shawn
