05-20-2004, 11:58 AM | #1 |
Front tire "screech" noise when turning around in 4wd???
Messing around yesterday and thought I better try out the 4wd on my new 71. Went down a real sloppy road no problem then came to the end where it was asphalt. I made a sharp u-turn and the front tire made a "screech...screech....screech" noise. Is this just because the hubs are locked in or something?
1972 K-10 Longbox,6" lift w/35's/350/SM465/NP205/3.73 1972 C-10 Longbox,350/350 1998 Pontiac Grand Prix GTP FOR SALE: 1971 K-10 Longbox,350/SM465/NP205 |
05-20-2004, 12:43 PM | #2 |
Yes, that is very common. It comes from the tendancy of the truck to "push" thus sliding the tire on the pavement. It would do the same on dirt/gravel you just don't hear it. The straight axle front end may do this even when not locked-in but the power applied makes the situation worse.
05-20-2004, 06:56 PM | #3 |
It is driveline bind. You should not use 4WD on pavement like that, particularily making sharp turns.
Tim |
