05-20-2004, 06:22 PM | #1 |
Front disc conv. 1 ton dually
Has anyone done this . I assume the parts for a dually 1 ton are different than single wheel due to the difference in the offset of the dually rim.
69 c-30 dually flat bed & dump ( best truck ive owned 87 chevy dually 97 1500 classic 89 wellcraft |
05-20-2004, 07:03 PM | #2 |
I'VE PULLED A COMPLETE FRONT END OUT OF AN 82 1 TON TRUCK , & I'VE YET TO INSTALL IT IN MY 69 1 TON TOWTRUCK. I PLAN ON PUTTING IT UNDER IT SOMETIME THIS SUMMER. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
05-20-2004, 08:36 PM | #3 |
Lets us know how it goes there junkyardjohn, I got a 1979 one ton for parts if I need it... I spotted what looks to be a 68-69 in a field today....its got me interested too. But I prefer disc...actually I've never had a dually with drums yet but I sure like how my 72 stops with all the weight it pulls around. So Im interested in the swap also.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
05-20-2004, 10:39 PM | #4 |
I think the only thing you need are what some call the buds or the part that goes onto the rotor/drum to extend the rim away from the rotor so it sits back
05-22-2004, 03:19 AM | #5 |
3/4 ton disc spindles are identical and have the same part number as 1 ton disc spindles. Unsure about tierod ends. If you already have disc brakes on a 3/4 ton or a 1 ton srw, the ONE-PIECE duallie rotor/hub will bolt on and use your original caliper.
I do have a pair of duallie rotors that I don't need anymore. Shippimg from Alaska is usually prohibitive, however. |
